CB Antenna help
Discussion in 'CB Radio Forum' started by DARKMAT3R, May 20, 2016.
  1. DARKMAT3R
    DARKMAT3R Bobtail Member
    12
    May 19, 2016
    I want to run a mirror mount single antenna on the driver's side on a 2015 Cascadia of what I read they say to use a top load antenna any suggestions I have a brand new stock Cobra 29 LTD Classic.
    At the moment on a good day I'm getting out about 4 miles but I can hear people from a lot further with the stock integrated antenna.
    I don't want to talk to people a hundred miles away but I hear with the right antenna and a stock radio you can talk to people 10 - 15 miles away that would be good by me I just want them to hear me clear and I want to hear them clear
  3. darthanubis
    darthanubis Heavy Load Member
    825
    616
    Jun 26, 2015
    This has been covered already. You've got some reading ahead of you.
    But you can forget about talking 10-15 miles, clearly, on a regular basis. You don't have a linear, or the right barefoot radio, seven foot firestik or not. You also probably drive a Cascadia.
    Search the forum. Or just look at the threads that are on the first page of this sub forum .
    TheDude1969 Thanks this.
  4. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Get a truck specific mount
    Get good coax <---route it properly
    Get a decent antenna
    Get the SWR checked, and/or adjusted
    Get talking!
    If top load is what you want, I suggest any fiberglass taller the better.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    I was out today messin around and had a thought...HHHMMM how do i raise that coil..BAMN i remembered i still have the 20" shaft off my comp predator..So i took off the 6" and slammed on the 20..Ill post a before and after pic of what it was and now is..Tuned pretty good to...Only prob is i pick up more electrical noise as i go by houses and some cars..Thats a bonding issue correct???
    I didnt climb up or measure total length from mirror mount but im darn close or a hair over that 13'6"
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Volvo244t had a good solution minus the counterpoise.
