I had put a 30 inch shaft on my new brownie cb antenna. Now SWR is over 3. How much should I cut from the stinger please? Thank you
Cb antenna
Discussion in 'CB Radio Forum' started by bojangles1953, Feb 15, 2017.
Page 1 of 6
rabbiporkchop Thanks this.
Don't touch it until you check your ground potential and have an antenna analyzer handy, otherwise you are likely to cut it too short.
wolverine11 Thanks this. -
Thank you. The ground is good cause the antenna I got on truck now has a 1.3 SWR. I had a low SWR with the short 6 inch shaft on my brownie. I think I have to shorten stinker to compensate for long shaft. Thank you very much. I'll let you know SWR after I get it done. Thanks
Yes slowly trim your "stinker" if you want but im sure da mrs would preferr you trim the stinger..
bored silly, BTShepp and bojangles1953 Thank this. -
What will I need to buy to cut stinger ? I have no ideas!!
Some are easier to cut than others but you can
Bolt cutters
Cutting wheel adapter for a hand drill
Cuttin torch..
Hack saw -
Thanks.
Page 1 of 6
