CB Goes FM
Discussion in 'CB Radio Forum' started by Timin770, Jul 31, 2021.
  1. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    "The addition of FM as a permitted mode will not result in additional interference because users who hear unintelligible audio on a particular channel can simply select another channel or switch modes."
    Meteorgray Thanks this.
  3. Antinomian
    Antinomian Road Train Member
    2,180
    3,471
    Feb 17, 2013
    The funny thing is the Brits lobbied for years to be allowed to use AM instead of FM.
    Meteorgray and Timin770 Thank this.
  4. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Like the YouTube dude said, I think they should allow FM on a few channels. Not all 40
  5. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    :D it would most likely be done the same way SSB is done...you can use it on any channel you want, but most people will go to certain channels to talk on it...IMO it's "not" something worth looking forward to... If it was all that great, then why would the Brit's be wanting to use AM legally? "Because FM sux!":p
  7. Antinomian
    2,180
    3,471
    Feb 17, 2013
    FM doesn't suck. It just doesn't have the same range. That might not be so bad since nearly all CB conversations nowadays happen in truck stops and at traffic backups anyway.
    Buddy Stinson and Timin770 Thank this.
  8. Ridgeline
    22,744
    123,732
    you guys … 10 meter fm, 120 miles with 100 watts.
    I think the reason why fm isn’t used in the 11 meter band here in US is the National Telecommunications and Information Administration.
  9. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Hmmm... sounds like the CB industry is trying to give the GMRS industry a run for their money. I believe GMRS radios are FM.
  10. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    IIRC anytime I accidentally transmit on FM it makes the SWR run high. I wonder if a person would need a different Antenna set up if they are going to run on FM
  11. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    No, FM vs AM is irrelevant as far as SWR. An antenna doesn't care about FM or AM, only the frequency of the signal. You're getting a high SWR because your SWR meter can't read FM if it's for CB, as that is an AM signal. You would need an appropriate SWR meter for that frequency, FM. FM or AM only have to do with the modulation type of the signal, not the frequency. SWR only goes up if you change frequencies, not modulation types. It's the same reason why when you have an illegal CB amp if you want to use it on AM or SSB you have to select that with a switch on the amp itself.
    Just like TV antennas don't care about digital vs analog signals. TV is still the same frequencies that it's always been. Just the TYPE of signal sent at those frequencies is different. This is why there is no such thing as a digital "HD" antenna. The old TV antennas work perfectly well with the new digital signals. You just need the proper receiver inside the house to convert the digital signal into a picture. Whether or not the signal is HD or not is determined by the transmitter, not the antenna on the receiver.
    mike5511 Thanks this.
