CB PA not loud with amp?
Discussion in 'CB Radio Forum' started by ncp546, May 31, 2017.
  1. ncp546
    ncp546 Bobtail Member
    5
    I have a uniden pro520xl with a 120 watt amp and a 100 watt radio shack powerhorn. When I hook up my cb to the PA system I have to yell to get it to sound barley. If I hook my iPhone up to the powerhorn and amp it puts definitely out 100 watts, its very loud and clear, the cb on the other hand I don't think it even pushes out 5 amps and its very distorted. I have played with the squelch and rf gain and I haven't noticed a difference. The amp is turned all the way up and so is the cb. Its very disappointing I have a lot of time and money invested into this system and I would like to make it right! I am attaching a video to show what its like. Any help is appreciated...
    Nick
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Did you get the radio tuned to the amp?
    If so they probably really lowered the mic input and radio output to under 1watt, makes it less distorted running through the amp.
    Disconnect your amp, borrow a power mic from someone, and try it that way.
  4. ncp546
    5
    I did not have my radio tuned to the amp, is this something I can do myself?
  5. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Squelch and RF only adjust incoming radio signals...
    @rabbiporkchop?
  6. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    My advice would be to try some else's CB. The uniden is only a 50$ radio, you don't have s gain control or good mic on it.
    Find a local cb shop and have them show you the difference with a better radio.
  7. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    squelch puts a wall up that incoming signals have to jump over before you're capable of hearing them and RF gain pulls a curtain down which filters out noise but still allows you to hear distant signals
  8. Ridgeline
    22,752
    124,040
    You all need to learn how to read his statement and the question, you all got it all wrong.
    Nick, Read my post carefully, it will give you an idea of what's going on.
    There are a couple issues I see with this, but not being there it is hard to determine which it is.
    I assume that you got a Plye PLMRA120 amp, that's what it looks like. AND you got the speaker have.
    First issue is with your wiring diagram, it is wrong.
    DO not split the input to the amp, go directly from the CB to the amp with one input.
    BUT don't do anything yet until I explain what's going on.
    You have what appears to be an impedance mismatch on the input of the amp.
    The CB is looking for an 8 ohm load and it is seeing 100 ohm load on the amp which will cause the problems you have.
    The reason that the Iphone sounds good is because the iphone can driver up to an 80 ohm load without an issue, the ear buds are 40 to 70 ohms impedance depending on the manufacturer.
    The mismatch is where the distortion comes from and trying to drive the high impedance load with only 4 watts of audio power further aggravates the issue.
    My suggests are really not the best one I can think of not being there.
    You can get a cheap preamp with a matching circuit and put that behind the CB to adjust the system for the right impedance into the amp.
    You can get a matching transformer to bring down the impedance n the radio side or in other words boast the impedance up.
    There are a couple tricks that can be used with resistors and chokes to do this but that's complicated.
    Those are all things I can't help explain and don't think they would help out right away, they don't make an 8 to 100 ohm matching transformer that I could find doing a quick search and a pre-amp you really have to search for one that works like that.
    SO here is another go to a good mobile audio shop and see what they have for a solution, because your issues are all on the input side of the amp, no where else.
    Hope that helps you out.
    Blaskowitz and Dirtymartini15x Thank this.
  9. ncp546
    5
    THANK YOU! Definitely a good lead. Can I ask what would be the "input" on the cb to the amp? I have tried completely bypassing power to the cb from amp. I hooked the cb directly up to the battery and I got the same results
  10. Ridgeline
    22,752
    124,040
    I wasn't talking about the CB power, you can use any source because both of them are tied to the same system within the vehicle. I am talking about you splitting the output of the PA jack on the CB to the input of the amp as it is illustrated on your diagram, if it is accurate, that is a problem because you have split between channels and then use on channel on the output to the speaker. use just one input and one output.
  11. ncp546
    5
    Great! Trying today. So on the speaker I have one of the wires that says "positive" and other that's black. Right now the speaker wire is hooked up to the positive and ran to the amp that is marked speaker with + and the black wire is ran to the - on the amp that's marked speaker. I should take both of those and put them into the + on the amp that is marked speaker correct?
