CB problems
Discussion in 'CB Radio Forum' started by rslivelyjr, Mar 14, 2023.
  1. rslivelyjr
    rslivelyjr Bobtail Member
    39
    10
    Mar 14, 2023
    Me and my friend work for the same company. We both drive 2019 model peterbuilt trucks. I believe 379 or 389 long nose if that helps.
    He bought a Galaxy 94HP , had it peaked and tuned. On a dummy load it dead keys 20watts and swings 200watts. He also bought a 4.5ft skip shooter and replaced his coax with a 18ft rg8 50hms .
    Now he has the antenna mounted on the top of the drivers side mirror bar. His swr is nice at 1.1 on 1 and 1.2 on 40.
    He can only get out at least 3-4 miles that’s it. That’s stYing still and driving . Pushing that many watts , should he be getting out further? We live and drive in Alabama , so the terrain is t ideal, but it should be more than 3-4 miles. We have tried everything we know to do. Different antenna, mounting locations . Any advise will help thanks
  3. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    The difficulty in getting radio checks may be a problem. If the radio is getting out 20+ miles maybe the receiving stations don't have the power to get back to him.
    One trick I do is place a voice-activated voice recorder next to my base station and then drive away from the base station, transmitting on my mobile every mile or so. A review of the voice recorder tells the story
    rabbiporkchop and Coffey Thank this.
  4. Diesel Dave
    9,715
    33,174
    Jan 20, 2010
    Hesperia, Ca.
    His problem is probably when he got the radio “Butchered”(Tweak n peaked)by the golden screwdriver. What mic is he using ?
    rabbiporkchop Thanks this.
  5. rslivelyjr
    39
    10
    Mar 14, 2023
    Well I’m the other “ear” , like I’ll sit somewhere, or while we are driving , we will be on the phone with each other , and then try radio checks and see if we can hear .
    Timin770 Thanks this.
  6. rslivelyjr
    39
    10
    Mar 14, 2023
    Ranger mic
    Diesel Dave Thanks this.
  7. Diesel Dave
    9,715
    33,174
    Jan 20, 2010
    Hesperia, Ca.
    Those mics for me or my application has always worked best(SRA 198). Who did the butchering on the brand new radio ? Also, that kind of power, your power source should come directly from the battery(wired with a fuse).
  8. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    That's a good way to do it. Random radio checks are of dubious value
  9. rslivelyjr
    39
    10
    Mar 14, 2023
    He’s running power from the stock wires from the roof mount. He did change the fuse and put a bigger fuse in the slots in the truck . Radio sounds good when you hear him no noise .
  10. Ridgeline
    22,742
    123,697
    Put the right fuses back in, if it blows than find another way to power the radio.
    krupa530 and Diesel Dave Thank this.
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Want to get out farther?
    Get a longer antenna...4.5' will keep your SWR in check, and get you out a few miles, but to get any real distance your going to need a antenna in the 6 to 7 to 9' range....just no way around it...
    OR...sell the 94HP, and get a Uniden PRO520xl and a 1x2 amp and people 4 States away will be giving him radio-checks...
    High Stepper and Diesel Dave Thank this.
