CB radio newbie
Discussion in 'CB Radio Forum' started by AnarchoTrucker, Aug 24, 2022.
  1. AnarchoTrucker
    AnarchoTrucker Bobtail Member
    Aug 24, 2022
    Flyover Country
    Most of my experience with CB's has been in trucks that already had good CB setups. I just got into a 2018 Cascadia Evolution (not new Cascadia) that came with a janky setup. I'm working on changing that. Just ordered a peaked Texas Ranger TRE292 and external speaker from Wolcott Radio that I'll install this weekend.
    What I need with help next is the antenna. Do I go 1 or 2 antenna route? Where to install? Mirrors or rear of cab or roof? How do I route the coax cables to these locations?
    I've searched endlessly and I keep coming up with solutions for other trucks and being new to actually choosing/installing CB parts I just don't know where to begin.
  3. AnarchoTrucker
    Aug 24, 2022
    Flyover Country
    Btw, the truck is a midroof sleeper with the top fairing removed. So there is already holes where the brackets were that held the fairing on. Curious if these could be utilized to mount the antenna(s)?
  4. Ridgeline
    22,755
    124,102
    Buy a radio properly tunes and aligned, the radio isn’t important- the antenna is so one antenna, read about bonding and grounds in a crapcadia.
  5. Neverready
    Neverready Medium Load Member
    406
    330
    Jul 24, 2014
    Pocomoke City, Md.
    Ridgeline is right. There are lengthy threads already here on Cascadia antenna mounting. They have to be one of the worst for antenna issues. If you hook your nice new radio up to a poor antenna system you can wind up damaging the radio. Another consideration is what are the power requirements for the radio? Will the factory harness provide the needed power? Radios with increased power will generate more heat, does your mounting position allow for a little air circulation? Good luck with your installation.
  6. jdchet
    jdchet Medium Load Member
    542
    771
    Sep 3, 2012
    NE Ohio
    Look up @craig_sez on YouTube. Good videos on how to setup an antenna on a Cascadia.
    JD
  7. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Grins...
  8. TCWPIONEERS
    TCWPIONEERS Bobtail Member
    7
    I bought a cobra 29lx and a firestik k-9a rg59a/u two antenna coax with firestik ss-194 antennas. Did I screw up and what can I do to get better performance out of what I already bought?
  9. Powder Joints
    8,023
    8,485
    Sep 25, 2007
    Rosamond, SoCal
    It will work, make sure that you do not ground out the antennas when you install them. You should probably get around a 1.7 or so SWR out of that setup. If its over 2.0 theres a problems.The lower the swr the better. 1.1-1.2 is ideal . Install it and checkback.
    TCWPIONEERS Thanks this.
  10. TCWPIONEERS
    7
    My main concern is the coax. Should I have bought a 213 coax
  11. TCWPIONEERS
    7
