CB radio
Discussion in 'CB Radio Forum' started by spallaxo, Apr 30, 2020.
  1. spallaxo
    spallaxo Bobtail Member
    Hey I just bought a Cobra 29lx and the truck I was assigned the other day has all the wires however there is no black or red wire like on the radio, just green and white. Which wires do I connect together?
  3. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Get your voltmeter out and check each one to ground. If neither has 12vdc check the fuse in your panel.
    If you hook the CB up reverse polarity it can let the brand new factory smoke out.
    And btw, you need to tune the antenna length or the CB will work like crap and eventually die.
    tscottme Thanks this.
  4. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Use a test light or just hook em up and cross your fingers
  5. Hazmat Cat
    Hazmat Cat Medium Load Member
    636
    1,778
    Oct 18, 2019
  6. spallaxo
    Okay, thank you. Do they make cigarette lighter plugs that have the black and red wire out, maybe connect them to the cb?
  7. tscottme
    tscottme Road Train Member
    Yes they do. Using one will make a wire from you cig lighter to the back of your radio. I'd buy the cheapest voltmeter at walmart though. It has more use and allows you to use the factory power leads.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Lick your fingers...then grab just one of the wires with your wet fingers...take other hand and touch something metal...You should be able to figure out which one is HOT fairly quickly....
    Once you figure out which one is HOT, connect that wire to the radios RED wire...The radios black wire can just be connected to a grounding screw somewhere under the dash...
    650cat425 Thanks this.
  9. Ridgeline
    22,752
    124,029
    No no no ... get a volt meter a light tells you nothing.
  10. Muddydog79
    820
    2,147
    Apr 14, 2016
    Well if two wires are already preinstalled from the factory, and in place where the cb mounts, id say one is hot, one not. Light would work
  11. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Could be hot with 24 volts
