Cb replacement recommendation
Discussion in 'CB Radio Forum' started by aramil248, Jul 12, 2019.
  1. aramil248
    aramil248 Road Train Member
    1,765
    2,043
    Jan 16, 2017
    Maine
    So the 19 peterbilt 579 I was put into doesn't have the space for my current radio. So I'm wondering what to buy that fits. Picture is of the space I got to work with 15629527628531562938982835377748.jpg
  3. skellr
    skellr Road Train Member
    8,735
    12,190
    Jul 17, 2011
    The Village, Portmeirion
  4. Windmill Hill
    Windmill Hill Light Load Member
    52
    20
    May 26, 2019
    Central Indiana
    I'm with skellr on that one.
  5. rabbiporkchop
    9,690
    6,573
    Feb 9, 2012
    Wapwallopen, Pa
    What's your current radio?
  6. aramil248
    1,765
    2,043
    Jan 16, 2017
    Maine
    don't remember. I will check when I get home
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Best thing to do would be get a tape measure and see what the dimensions of the hole is...Most of the radios listed on line will also tell you in the ad's the dimensions of the radios...Just be sure to allow enough space for the antenna connection in the back...If necessary you can use a elbow connector to hook the coax up which can save you a inch of space in the back...
    I agree with the McKinley, it's about the same 1DEN size as most car stereos so it's a ideal choice for mounting in tight spaces...
  8. skellr
    8,735
    12,190
    Jul 17, 2011
    Uniden 880? That should fit. The flat plastic just inside the cubby looks like it is a separate piece, it will probably pop off and make more room.
  9. aramil248
    1,765
    2,043
    Jan 16, 2017
    Maine
    just checked if you can pop that out. All but the bottom seems like it
  10. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,186
    May 12, 2012
    SouthEast Alabama
    The piece where the mic holder is, is one piece from the door window to about half way to the center of the windshield. A little bit of pressure will pop that entire piece out allowing access to more space. On my current truck, the cb connection posts are behind and to the left of the flat surface that is adjacent to your mic holder. When you get the trim panel off, you will probably be able to remove that flat piece. On mine, there is a small cubby hole box that is snapped into place with tabs on the left, right, and rear sides. I've got a Cobra 25 Classic but that area will hold a larger CB.
  11. aramil248
    1,765
    2,043
    Jan 16, 2017
    Maine
    IMG_20190726_164607.jpg so I did that and have no clue what the hell did the last driver did to the cb wires
    88 Alpha Thanks this.
