Cb settings
Discussion in 'CB Radio Forum' started by sbaumann14, Jan 17, 2020.
  1. sbaumann14
    sbaumann14 Road Train Member
    1,238
    1,433
    Sep 1, 2010
    Rhinelander, WI
    So where do you guys like to run your CB? With your squelch all the way open and your gain down just enough so the static stops? Or your gain all the way open with your squelch down just enough to where the static stops? Just curious
    feldsforever Thanks this.
  3. mitrucker
    mitrucker Road Train Member
    5,490
    10,327
    Dec 15, 2010
    Lapeer, MI
    My preference is the second one.
    Timin770 and buddyd157 Thank this.
  4. sbaumann14
    1,238
    1,433
    Sep 1, 2010
    Rhinelander, WI
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    I agree with mitrucker. I’ve tried using the rf gain as the squelch like some guys do. The problem I found was that since the rf gain lowers the audio volume too, I would miss the first few words someone said. It was because I would have to turn the gain down while going through a town due to static from the electronic signs and stop lights. But then later after going through town, sometimes I would forget to turn my rf gain back up to hear. I found if you use the squelch instead, at least when I forget to turn the squelch back down, and someone close enough breaks the squelch, I can hear them due to the volume is still loud.
    sbaumann14 Thanks this.
  6. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    the second one, when i had my cb turned on.
    Timin770 and mitrucker Thank this.
  7. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Yep, gain all the way up and the squelch to control the crap, for me.
    I've got a couple of (cheap) radios that don't even have gain control, but the squelch knob is always there. They obviously are set at max gain as the only choice, which works for me.
    Timin770 Thanks this.
  8. gummy bear
    gummy bear Light Load Member
    245
    118
    Nov 8, 2008
    kentucky
    I've always run squelch wide open and back off the rf gain. It's worked for me for the past 16 years, anyway
    slim6596 and D.Tibbitt Thank this.
  9. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    Ya, but think of all those gummy BEAR reports you’ve missed out on by running with your rf gain down.
    D.Tibbitt Thanks this.
  10. Meteorgray
    754
    597
    Jan 1, 2016
    LOL. I don't think it makes any difference. There are many on either side of the choice. It's nice to have choices. Hope we always do.
    Night Stalker10 Thanks this.
  11. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I just turn the rf gain down just a touch to take the edge off the static, not enough to make it stop or quiet, just to soften it. It's helps to tell how much you can turn the rf gain down when you hear a faint signal so you don't go too far with it.
    If you listen to static enough you will just mentally tune it out and rarely notice that it's there. Like a loud ticking clock in a house, after a while you don't even notice the ticking.
