CB SETUP
Discussion in 'CB Radio Forum' started by Mcast3092, Oct 27, 2022.
  1. Mcast3092
    Mcast3092 Light Load Member
    137
    107
    Jul 31, 2018
    Hey everyone just looking for some advice and what to do for my CB radio set up. I have a 97 T600 and I’m pretty much setting a CB up from scratch. I have a galaxy DX 959B. Do you guys have any equipment recommendations as far as antenna and coax cable? If there’s anything else I need please let me know ill most likely be doing it myself. Also I do a lot of driving from New Jersey to Tennessee and I come across a lot of CB radio shops anyone know which one might be the best my route is pretty much 81 and 40. Thanks in advance
  3. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    I used the Hustler FG27S 48 inch antenna for years. Stainless steel and not a big wind catcher. RG8X coax will work just fine with the Galaxy 959 cb radio. The Hustler HQ27 antenna is 55 inches and will probably perform a little better than the FG27S. Sure you can get a tall skipshooter or a predator 10K, but then you have to spend more dollars on bigger mounts. I just keep it simple, but that's just me.
    Mcast3092 Thanks this.
  4. Ridgeline
    22,749
    123,895
    I replied to your post in Owners section,
  5. Diesel Dave
    9,727
    33,295
    Jan 20, 2010
    Hesperia, Ca.
    Guess he didn’t like the other responses and started another thread on the samething .o_O;)
    Tall Mike, rabbiporkchop and RJM1953 Thank this.
  6. Mcast3092
    137
    107
    Jul 31, 2018
    I asked the question on the CB forum upon his suggestion actually
  7. Mcast3092
    137
    107
    Jul 31, 2018
    I appreciate the info, I’m desperate to get it up and running but I want to do it right the first time
    Timin770 Thanks this.
  8. Diesel Dave
    9,727
    33,295
    Jan 20, 2010
    Hesperia, Ca.
    I see, the mods never moved your original thread to the “CB” section, gotcha. :cool:
  9. Ridgeline
    22,749
    123,895
    I suggested that but it wasn't caught, should have reported it to the team.
    I am not upset, I want the OP to get the right and best info, this is why I just pulled the quotes down here so to say to others to start with the antenna and coax, focus on the grounds because that will be needed and have others from this section comment on what he has done.
    Neverready and Diesel Dave Thank this.
  10. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    With the antenna mounting bracket so low to the ground, Ideally you would be looking for an 81 inch antenna to reach your height restriction and minimize coil losses caused by using an antenna That's too short but a coil too long. Ideally, the coil should be as short as possible and the antenna should be as long as possible within your height restriction. Sometimes it's easier to build something custom for that truck than it is to find something that's ideal and available over the counter.
