CB to GMRS Conversion?
Discussion in 'CB Radio Forum' started by russbrill, Jun 11, 2021.
  1. russbrill
    russbrill Medium Load Member
    324
    224
    Nov 10, 2017
  3. russbrill
    324
    224
    Nov 10, 2017
    Heads up, Midland is coming out with a newer radio called the MXT-500. It will have more programming flexibility, 50 Watts of RF Power, and the NOAA weather channels.. It should be available by the end of Summer 2021...
  4. Autocarjockey
    Autocarjockey Bobtail Member
    27
    59
    Jun 28, 2021
    A 15 watt midland and a no ground plane NMO antenna on the mirror will easily outdistance any CB setup
  5. Timin770
    Timin770 Road Train Member
    1,586
    1,636
    May 27, 2011
    Canton, GA
    That's what it's going to take: some of the bigger shops and truck stops to devote a little shelf space to gmrs
  6. Night Stalker10
    Night Stalker10 Road Train Member
    1,530
    1,039
    Jun 26, 2017
    Have you tested this theory?
  7. Autocarjockey
    27
    59
    Jun 28, 2021
    I do it every day
    I have a 5/8 over 5/8 NGP 5Db gain antenna and a 15 watt Midland and the only place where my export CB works better is in the mountains where the UHF frequencies tend to get blocked by the hills.
    The Midland MXT400 is 40watts which i'm sure will go a little further for $250
    Or you could buy something like this 50 watt Baofeng
    BTECH Baofeng GMRS-50X1 Repeater-Capable Radio GMRS 50W
    • Regular price $199.99
    Timin770 Thanks this.
  8. Timin770
    1,586
    1,636
    May 27, 2011
    Canton, GA
    Russ do you have any idea how the Midland will compare price-wise to the backordered Wouxon (sp?)
  9. Meteorgray
    Meteorgray Heavy Load Member
    754
    596
    Jan 1, 2016
    Do you ge
    Who are you talking to?
    Do you get traffic reports and other road info from other drivers with that GMRS? How about info at loading docks? Or what is it used for in the truck?
    Tb0n3 Thanks this.
  10. russbrill
    324
    224
    Nov 10, 2017
    The Wouxon KG1000G is in a class by itself. It has 999 custom memories, General Coverage VHF/UHF Receiver, FM Wide and Narrow Band capable, and has TWO independent receivers.
    Midland is playing "catch up" :)
  11. Autocarjockey
    27
    59
    Jun 28, 2021
    Just like when CB began to be used by truckers it too was EMPTY and quiet back then until enough drivers bought radios and GMRS is no different.
    I still use channel 19 on the road just like everybody else and it's not going to get replaced any time soon by GMRS but when i only want to talk to one or two drivers heading the same direction, i use GMRS if they have it and every driver in my company has them.
    You hear NOTHING until the people you WANT to hear key the mike instead of having to turn the squelch all they way up just to block all the good buddies and racket.
    Meteorgray Thanks this.
  • Draft saved Draft deleted
