CB transmits but not receives
Discussion in 'CB Radio Forum' started by razor1983, Mar 17, 2014.
  1. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    What could it be? I did break off the passenger side antenna on some branches, which I removed.
    I think its the Cobra 29, very rarely use the thing.
  3. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Your antenna set up is bad if you took the antenna off now you have coax not hooked to anything also you will blow out your final in the radio if you keep using it.
  4. BigBearNY
    BigBearNY Light Load Member
    160
    37
    Mar 14, 2014
    You also CANNOT use the coax from a dual setup with a single antenna. Different OHM ratings. If you want to use the single antenna you`will have to replace the co phase harness with a 50 OHM coax.
  5. Razor3
    Razor3 Light Load Member
    115
    38
    Jan 27, 2014
    North Central, AR
    +1 to what BigBearNY said.....
    If you were originally running a co phase setup then you're coax is 75-ohm.
    Two different solutions really: Either get another antenna to replace the one you broke off and hook back up like you originally had it or get a 50-ohm coax to hook up to you're good antenna and just run one.
