CB tuning troubles
Discussion in 'CB Radio Forum' started by Bighorsecowboy, Jan 12, 2015.
  1. Bighorsecowboy
    Bighorsecowboy Bobtail Member
    Have a Peterbilt 379
    with a Wilson 5000 cab mounted in centerfold cab
    using a cobra 29 LX LE
    Swr cal is cranked up and still not properly tuned
    Swr is still@ 3
    Any suggestion
  3. RoadCall
    RoadCall Road Train Member
    1,496
    943
    Mar 12, 2012
    What does this have to do with "bad" trucking companies?
    Might want to post this in the CB section
    Ditch Doctor and d o g Thank this.
  4. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Get some sleep and come back when you can write a understandable question????????? ;-)
    Seriously, sounds like one of two things. Not using the SWR meter properly, if you are even using a meter instead of the built in inaccurate one. Or, bad RF ground......not something you can fix by just running a ground wire!
    jessejamesdallas Thanks this.
  5. EZ Money
    EZ Money Road Train Member
    Sounds like he does not understand the SWR calibrate knob.....
    Turn meter to FWD,key the Mic and adjust knob to right so needle is at set mark,
    Turn meter to REF,Key Mic....that is SWR reading..
    The built in meters are junk anyway.
