CB won't turn on.
Discussion in 'CB Radio Forum' started by TruckerNate, Sep 13, 2013.
  1. TruckerNate
    TruckerNate Light Load Member
    68
    10
    Dec 5, 2010
    Grand Forks, North Dakota
    Someone told me it was a fuse that blew and needs to be replaced, I heard the red lead is where the fuse is located at or the rear of the cb radio but I don't know what it even looks like. Also I heard it could be the diode, just wanna get my cb working again, it's a brand new cobra 29 LSX. If someone could show me what I'm looking for so maybe I could get a new fuse or diode and solder it on I'd appreciate it. Thanks.
  3. Pilgrim007
    Pilgrim007 Light Load Member
    125
    80
    Sep 9, 2013
    Chances are it is the fuse.. Behind your rig the red wire should have a white plastic connector that twists apart. Inside is a Fuse. Just replace it you can't tell its OK just by looking at it. If you don't have a fuse, temporarily just for listening!! You can use a thin piece of tin foil from a cigarette box. (Just the foil not the backing paper) tear a piece off and gently wrap it round the fuse so both ends are covered. ASAP change the fuse for a new one and keep some with you. Fuses normally blow because of a short, a loose connection could also be the problem. If a replacement fuse blows have it checked out. A short can cause a fire...
    TruckerNate Thanks this.
  4. TruckerNate
    68
    10
    Dec 5, 2010
    Thanks that was the info I was looking for. Where are some places where I can buy me some cb radio fuses?
  5. TruckerNate
    68
    10
    Dec 5, 2010
    I do have a loose connection so that must be the culprit, have to do something bout that.
  6. Pilgrim007
    125
    80
    Sep 9, 2013
    Truck Stops, Radio Shack possibly Walmart, just take the old fuse with you and ask for a replacement packet..
  7. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    those are just auto fuses, you can buy them just about anywhere.
  8. TruckerNate
    68
    10
    Dec 5, 2010
    Alright, time to do some fuse shopping then.
