High guys first post here I driving a 2010 peterbilt 379 day cab well I was installing my connex 4600 turbo today and I hooked it a all up had swr meter on to start calibrating my antenna when the cb died as soon as I hit the mic, I tried the stock cobra 129 it doesn't turn on either I checked the fuses at my feet and under the hood and everything there was good. I have a buddy who told me there's an inline fuse in the headboard that either needs bypassed or a bigger one needs put in place to run my connex is there any truth to that the fuse being there that is I'm not sure how I feel about bypassing it if there is one there, I couldn't get up in there to see I didn't have the torx bit for my driver
Bryan
Cb won't turn on
Discussion in 'CB Radio Forum' started by Oilfieldoutlaw, Oct 16, 2013.
Never increase the size (rating) of a fuse; it's there to protect the wire between the battery and wherever it is against too large a load, whether it be a dead short or just too large a current draw for the size of the wire.
Typically, any radio with a transmitter that puts out more power than a stock/legal CB ought to be run straight to the battery, both for hot and ground. The hot (at least) should be fused right next to the battery with a fuse that's rated for whatever current that wire can carry (like, f'r instance, if you run a 6 gauge lead to the battery for a radio and other goodies), and a *second* fuse inline with the device that it's running, like the radio, rated for just that device's current draw (plus ~50%), immediately adjacent to the device (the radio, in this case). A radio that usually draws up to 2 amps is often fused at 2.5 or 3 amps to allow for short current draws, like when the receiver is turned up really loud, or other random vagaries.
Putting a larger fuse than is specified in the headboard (or jumpering around it) is a near-certain recipe for a disastrous fire. So far, it sounds like a fuse (or fuses) saved your proverbial bacon from all that expensive smoke they build into the radio being released inside your cab on the highway.
As long as you've got a metal roof and/or a decent counterpoise, I'd personally try a stock CB before moving up to more power (which does nothing to help your receive sensitivity or performance.)
That's just my two cents
73TheDude1969 and KW Cajun Thank this. -
Fuse/wiring topic explained very well by handlebar.
I think handlebar's two cents is drastically underpriced.
Awwww, y'all 're gonna make me blush....
And thanks very much for the endorsement.
73
