Celadon: What kind of runs would I be making?
Discussion in 'Celadon' started by Rawesome, Jul 1, 2013.
  1. Rawesome
    Rawesome Light Load Member
    55
    9
    Jun 29, 2013
    Asking around about the companies I'm interested in. Can anyone tell my what type of runs I'd be making with Celadon? And what my schedule would be like? I'm based out of Virginia, along the north portion of I-81. Thinking about joining the long haul fleet. Many thanks for any replies!
  3. Chinatown
    Chinatown Road Train Member
    77,980
    185,582
    Aug 28, 2011
    Henderson, NV & Orient
    Check with Schneider bulk/tanker about their runs. I think that division hires out of VA & tanker is where the money is.
  4. Rawesome
    55
    9
    Jun 29, 2013
    Thanks Chinatown, Schneider is on my list of companies. I don't want to start out with tanker though, or reefer... Really looking for dry van.
  5. Atlas117
    Atlas117 Bobtail Member
    28
    27
    May 20, 2013
    Over the road, they ask you to stay out for two weeks minimum between time off requests - three weeks if you want to make any money. You could run anywhere in the lower 48 + Canada; they'll have you apply for a passport if you don't have one (at company expense). Most Canadian runs will take you south of Toronto. Once in a while we'll have runs close to Montreal, Winnipeg, etc. but they're somewhat rare. Shouldn't be too hard to get you home to that part of Virginia. Any questions, let me know. I dispatch for Celadon.
    newbietrucker007, Flex and Rawesome Thank this.
  6. Rawesome
    55
    9
    Jun 29, 2013
    Atlas, thanks for the response. I do have a few questions if you don't mind.
    I've been out of CDL school since October and this would be my first driving job. What type of training would I need to get me in the driver seat?
    How much home time is available after two weeks of driving?
    What terminal is closest to me? I'm on the northern portion of I-81 in VA.
    I have family in California. Would it be possible to take home time out there occasionally?
    Would I be running in Mexico?
  7. Atlas117
    28
    27
    May 20, 2013
    1. You may want to contact recruiting about training/requirements - I don't want to tell you incorrectly. I don't think any more training would typically be required, as long as you have your CDL, but they may require some experience first. I'm not sure how much they're hiring out of CDL schools with no prior experience (the obvious exception being Celadon's new school...)
    2. Earned Days Off policy is one day off for every seven days out - you could take one day off every other weekend and then slowly build up some extra off days on top of that. 12 days out/2 days off on a continuing basis will take you into negative EDO fairly quickly. 13 days out/1 day off is more sustainable. Going home that often may not get you the miles you need to generate a good paycheck - but only you know what kind of pay you need. How do you feel about running Canadian freight? The drivers on the Canadian Regional fleet get home every weekend if they want to. They can also get some extra time off and extra pay for Canadian runs. If you want more details you can contact Indy dispatch and ask for the Canadian Regional dispatcher working that day. They would know more than me.
    3. Richmond terminal is probably the closest. We also have terminals in Carlisle, PA and Greensboro, NC.
    4. Yes, it's possible... not really easy. It would probably go into the system as a lower priority routing, but it can be done. It's something you would want to talk about with your dispatcher, should you end up working with Celadon.
    5. No; none of Celadon's U.S. drivers run in Mexico.
    Hope this helps.
  8. Rawesome
    55
    9
    Jun 29, 2013
    Atlas, that helps a lot, thank you. Canada sounds like an option. Will definitely call up the Canadian Regional dispatcher and get some more info.
  9. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    There are VA to Montreal runs.
    Rawesome Thanks this.
  10. Sequoia
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    The only downside to delivering in Montreal, or Quebec for that matter, is that all the signs are in French. In all the other provinces, the signs are bilingual with French and English but Quebec has to be different (there's a long story about that) and only have their signs in French. You'll quickly learn the basic words: north, south, east, west. Oh and stop...stop is a good one to know. Of course the dreaded phrase I never want to see is "sortie barre" which means 'exit blocked' which means you'll have to follow a detour. I had to follow one through downtown Montreal when my exit for a highway was closed for construction.
  11. dalazdayz
    dalazdayz Bobtail Member
    13
    fayetteville,nc
    why would you want to work for a company that doesnt pay its like working for free
