CH 18 IS CH 19
Discussion in 'CB Radio Forum' started by 12 ga, Mar 8, 2020.
  1. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    A couple weeks ago I noticed that my Galaxy's digital channel readout indicated 18 yet I was actually on CH 19.
    Any ideas what has caused this and will it hurt the radio to use it like that.
  3. TripleSix
    133,357
    Does your frequency meter say 27.185?
  4. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Doesn't have a frequency meter.
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Maybe you can give us more to go on. Like model of radio you have. Is it in a mobile environment or is it being used as a base station. Has it been working fine for a long time and then it started acting up? Are you on rough roads regularly? Also, have you checked the power for around 14 volts dc going into the radio? Low power can cause some weird problems with a radio.
    650cat425 Thanks this.
  6. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Did you see a similar offset on other channels, ie 17 is 18, 16 is 17 etc?
  7. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Don't know, only use 19.
  8. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    I believe the problem has been diagnosed by the shop that set it up for me.
    Timin770 Thanks this.
  9. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Cold solder joints most likely. I've had them do that more than once. Now if the frequency is drifting, it could be something else. Which I've also had happen before, but I'm not a tech and can't tell you how to fix it.
    12 ga Thanks this.
  10. 12 ga
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    It goes back in the truck Monday so I'll know for sure.
    mike5511 Thanks this.
  11. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Turn the 10KHz switch back off....
    12 ga and HopeOverMope Thank this.
