Chain to strap conversion
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by canadianredneck, Mar 13, 2016.
  1. canadianredneck
    canadianredneck Light Load Member
    229
    104
    Jul 26, 2012
    Western Arkansas
    Ran into a really nice Liberty driver in Vegas that had converted all chains to straps. He cut holes in the decks for the straps to come out and cut out a se tion of the roller and put Molly square rounded tubing 1 inch. Any other ideas suggestions? On my way to pick up an olde 8 car to put behind my freightliner. Can't sell it so might as well put it to work.
  3. skinnyb01
    skinnyb01 Light Load Member
    154
    212
    Feb 7, 2016
    Google ez tie soft strap. He's outta ontario canada. Did the top decks of mine it's a pretty simple conversion
    canadianredneck and Terry270 Thank this.
  4. Terry270
    Terry270 Road Train Member
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    http://automobiletransportsupply.ca/index.html
    Wasn't the first thing to pop up but I found it. Pretty cool, care to share the cost?
  5. canadianredneck
    229
    104
    Jul 26, 2012
    Western Arkansas
    Terry270 Thanks this.
  6. canadianredneck
    229
    104
    Jul 26, 2012
    Western Arkansas
    The one the liberty op showed me converted the chain to strap, he claimed less than 10 per station in parts, he did the welding tho. I am going to try starting with the bottom deck. On the top deck he has dual assemblies, one for the strap, one for the chain where the tire sets, one for the strap, it allows the tires up top to drop down a couple a inches for clearances.
  7. canadianredneck
    229
    104
    Jul 26, 2012
    Western Arkansas
  8. skinnyb01
    154
    212
    Feb 7, 2016
    Ok I've seen guys do that too but with some of the really low profIle cars you run into clearance issues ( on the 1st pic)
    The one on the boydstun decking works the best but just make sure you add some angle iron under the strap box so it doesn't sag
    canadianredneck Thanks this.
  9. sxdime
    sxdime Medium Load Member
    409
    551
    Nov 9, 2010
    Elkton MD
    The one problem with the above link (mod) is that it is normally installed in the center of the deck and not on either end. That causes issues with the tie down bar being way to close to the side of wide vehicles (suv's etc)
    craig512, canadianredneck and Terry270 Thank this.
  10. joeyg999
    joeyg999 Light Load Member
    103
    58
    Jan 5, 2015
    It is pretty simple to do if you have the right tools. You can cut the aluminum deck and weld round bar all the way around the hole. Then you can do one or two things with existing ratchets. Either plasma cut a slot where you need it to put the strap through or bend a piece of round bar so it is connected at both ends of the old chain ratchet. Just need a small gap to put strap through.
    After using the hooks in the aluminum deck for a while you'll notice the holes will ware out. I've reinforced the most common used holes with steel.
    Terry270 and canadianredneck Thank this.
  11. Terry270
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    Would you mind sharing how you reinforced the aluminum with steel?
    skinnyb01 Thanks this.
