Chaining up
Discussion in 'Questions To Truckers From The General Public' started by Jxdiver, Feb 5, 2021.
  1. Jxdiver
    Jxdiver Bobtail Member
    13
    8
    Oct 30, 2011
    Truckee, California
    Two questions here.
    Living in Truckee I see guys putting chains on all the time. I’d say maybe 1 out 10 guys are wearing some sort of rain gear to keep dry when it’s raining or snowing before going up to the summit. Are the rest just not prepared or just don’t care if they’re miserable and soaking wet when done?
    Coming back from Reno after they reopened Donner summit. I lost count after 20 seeing sets of chains in the middle of the road that had fallen off and numerous “starfish” type bungee cords as well. Are guys just not installing these correctly?
    It’s gotta suck when you get to Cain control and your missing a chain on a tire and can’t get through.
    I also saw in the chain up area a laid out set of chains and no truck.
  3. Life on Wheels
    Life on Wheels Light Load Member
    198
    177
    Aug 17, 2019
    New Orleans, Louisiana
    First question: you get a mixed bag with that. Some guys are so fast at chaining up, they don't bother putting on rain gear. Some drivers might do 90% of their driving in dry climates and don't carry that gear with them. They don't need it until they do...
    Second question: if the chains fall off, you don't put them on correctly. You have to put them on, then drive a little bit, then stop to tighten them. Some people drive to the end of the chain up area, some people drive a mile or two. You could also just roll back and forth right there if you have the space.
    Flat Earth Trucker and GYPSY65 Thank this.
  4. TravR1
    TravR1 Road Train Member
    3,695
    9,850
    Nov 9, 2017
    TX
    Lots of guys go their entire career and never have to chain. It just depends what you're doing.
    I've done it twice in 3 years. I don't know about others but my truck has extras. So if I lose a chain, I could just throw another one on.
    I don't know what's going on with the lack of protective gear. Personally I like to stay dry and warm as much as possible.
    One time I saw a guy get out in a blizzard with only low top shoes, sweats, and a sweater and proceeded to try and throw chains. It was one of those rookie carriers. Some folks just don't think far enough ahead.
    Cowboyrich and Flat Earth Trucker Thank this.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Guys driving too fast can throws chains off the truck too.
    Lucky12, okiedokie and IH Truck Guy Thank this.
  6. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    If I were to gear up in rain gear before I chain and then remove and stow that gear after it would nearly double the amount of time I spend in chain areas.... Its faster to just change out of wet pants after I've chained... If I even get wet enough to warrant the change.
    Chains can and do break... I'm not walking half a mile or more back on a slick road to retrieve one that broke and come off.
    alds, Cowboyrich, Lucky12 and 3 others Thank this.
  7. Espressolane
    18,807
    118,077
    Have had to chain on about every western pass over the years.
    I usually wear a pair of rain pants that are safety orange with reflective stripes, what ever jacket is on the seat. Wear the pants to keep from getting run over.
    alds and InTooDeep Thank this.
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I don't bother with rain gear as the coat, and two pair of gloves, will dry out in the cab with the windows cracked well enough to get the job done. They are faster to remove so I won't need a coat for that. It seems to work ok.
    Yeah, lots of chains fall off. I think it's mainly because they are put on too loose. Some of them could be worn out, and it doesn't take too long for them to wear out when they make you chain up 10 or so miles before you run into snow. Truckee isn't so bad, but I-70 in Colorado can be a pain in that regard. Running them on dry pavement eats them up quick, especially if you run over 25-28mph. Break a few cross links and they tend to get loose and come off too easily. Although, they should be loose enough that you can hear them flailing against the truck/trailer before that happens.... Ooff! Even then there isn't much you can do as there isn't a place to pull over and fix them for a while in most cases.
    It can happen, but I think most of the chains lying on the road are from improper application.
    LOL. :D Yep. We are both thinking the same thing on that one. Sometimes it's better to just pretend you didn't see it...
  9. AModelCat
    165,220
    Good chains don't normally break. Those cheap offshore ones I wouldn't trust to put on a lawnmower.
    skellr Thanks this.
  10. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    699
    1,077
    Apr 2, 2016
    Use to throw triples on the front axle in northern Ontario bush in 20 mins. -30C. No wet gear needed.
    skellr Thanks this.
  11. skellr
    8,735
    12,187
    Jul 17, 2011
    Too dang cold for wet!
    Canadian Humor. :)
    alds and aaronpeterbilt3787 Thank this.
