Chains.... how many seasons do they last?
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Dec 14, 2023.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    Assuming that you are able to maintain a complete set of chains(all 4 positions: both sides, drive tires and trailer tires, therefore 4 pairs)....
    How rusted do you let them get before seeking replacement? How many seasons should they get you before they reach that point?
    I'm starting with a new company soon and will be inspecting them if they aren't at least unused(still in the bags)....
  3. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    They clean up if you use them.
  4. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    Drive a few hundred yards with the chains on you'll find the rust will come off and they'll be bright and shiny once more, till you put them away and the air gets to them once again.
    beastr123 and Numb Thank this.
  5. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    Drag em on a dirt road behind a pickup. Then they will look more presentable.
  6. Commuter69
    1,142
    635
    Jul 2, 2014
    It's not a matter of wanting to ACTUALLY use them, it's wanting to be COMFORTABLE they aren't unsafe to use when I HAVE to....
    If I know there is a problem before I start moving, I AIN'T moving....
    I poked my head out my window one morning saw that I'd be ankle deep in snow that wasn't there when I parked and saw another driver with chains on at parking lot speed actually SLIDE in the lot. I felt unsafe even parked, let alone in motion! I called my office and said I'm staying put for the time being....
  7. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    Sounds like you really just don’t want to do the winter driving. The chains are rusty, fix them by dragging behind a pick up on a dirt road or hit them with some WD-40 and a wire brush. Move towards the direction of work never away from it. If everyone stoped when there was snow on the ground we wouldn’t eat. In the last eight years, running to northern states, I don’t think I shut down more than four hours for weather. I understand that things are out of peoples comfort zones and that’s understandable but without ever pushing yourself a little you will never graduate. Just do the best you can, little by little. Strive to be 2nd to none to no other and things will fall in place.
    loggedin, Coffey, Hammer166 and 10 others Thank this.
  8. Arctic_fox
    4,539
    25,726
    Sep 16, 2016
    Honestly a well cared for set of chains or even a badly abused set will last for many years. Your going to look for obvious thinning of the chains, physical damage, bent, damaged or missing links, tightners and so on or anywhere where the rust is excessive which will be ovious as surface rust is just rust, deep rust will have pitting, holes or soft spots and be really really obvious.
    As for slipping with chains on in snow. Only time you slip with chains on is A they are too loose/the wrong size. Or B the guy was trying to accelerate to quickily. Unless of course you have a ton of black ice but even there studded tire chains at a LOW speed will keep you from losing control in MOST cases. Where they wont will be VERY obvious.
    If your concerned that your chains are comprimised. Just ask for new ones. Most companys are happy to provide you with them as a set of new chains is much cheaper then a new semi.
    Magoo1968, Coffey, dwells40 and 5 others Thank this.
  9. mustang190
    mustang190 Road Train Member
    2,894
    6,258
    Jan 18, 2011
    Florida Panhandle
    I would be more concerned about black ice.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,990
    19,049
    Nov 1, 2010
    Burnsville, MN
    I don't know what my chains look like, They are still in the bag in a side box.
    I carry them, but I don't use them.
    Coffey, austinmike, dwells40 and 3 others Thank this.
  11. cke
    cke Road Train Member
    6,189
    76,165
    Aug 4, 2013
    Colfax Wi
    @Tug Toy Whats the proper way to take care of tire chains ??? lol :D
