chains
Discussion in 'Flatbed Trucking Forum' started by ford06, Apr 8, 2019.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    does anyone bother with 5/16 chains or do most of you use 3/8
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    157,231
    I use 5/16 , thats what my company provides, id rather have 3/8 though
    shawnhhllc, Tb0n3 and ford06 Thank this.
  4. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,601
    Oct 6, 2009
    Colorado
    at my company all the pipe guys (concrete pipe, with those specific trailers) all have 5/16th. All the flatbed guys have 3/8th.
    after throwing 3/8th all day slinging 5/16th is like baby weights. :)
    when i had my truck, i had grade 100 3/8th chain. (which is approximately the equivalent of 1/2" grade 70 at half the weight although you have to use 1/2 binders to keep the WLL up) but most companies are way too cheap.
    shawnhhllc, D.Tibbitt and ford06 Thank this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I've used both. They have their places. I've hauled combines with all 5/16, you just need to use more of them.
    shawnhhllc Thanks this.
  6. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    I carry 5 3/8 and 6-7 5/16. 5 3/8 70g will hold 50k single piece (coil, slab, ect). If I just need more for long pieces or multi pieces 5/16 will work for that. Helps keep my light weight down to.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I prefer big chain.
    Anything small is used to leash that doggie.
    BackwoodsGA Thanks this.
  8. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    I carry 3/8”. 7 16’, 5 20’.
  9. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    I carry 3/8", 10 at 20'. I dont think I've ever needed all 10.
  10. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    5/16 will do the job. You might need to throw another chain, or two, to meet requirements or your comfort level.
    3/8 would be nice at times, but having more tie downs spread across more anchor points does have some appeal. Especially with aluminum trailers. like Reitnouer trailers. (when not using J-plates/hooks)
    I'd want to have some 3/8 chains, but I don't think I would throw less chains because they were 3/8 instead of 5/16. Is it worth 3/8? Probably on a steel trailer. Aluminum? maybe...
    mpd240 Thanks this.
  11. Pedigreed Bulldog
    7,737
    14,423
    May 7, 2011
    What's the WLL of your attachment points on the trailer? Really no point in exceeding them with a heavier chain. If your attachment points can handle 3/8" G70 chain, then by all means use it. If they barely exceed the rating of a 5/16" G70 chain, why would you want to throw the heavier chains when you aren't seeing any benefit? Besides...a broken chain is much cheaper/easier to replace than a broken rub rail.
    kylefitzy Thanks this.
