Chameleon Tarp Systems
Discussion in 'Flatbed Trucking Forum' started by Salted, Jan 7, 2015.
  1. Salted
    Salted Light Load Member
    96
    22
    May 23, 2014
    Does anyone use something like this? If so how do you like it? Does it limit what loads you can or does it make more options for you?
    Thanks
  3. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    They are commonly called rolling tarp systems or Conestoga’s after the cover wagons that pioneers used to migrate out west and one popular brand of them. There are lots of posts on here about them.
    Probably the most popular brands are the Quick Draw, the Fasttrack 2, and the Conestoga 2.
    Yes, they can limit your ability to take any overwidth loads and loads that are higher then the tarp system is. The Fasttrack tarp system has a run open option that will allow you to take oversized loads though. Other brands may have a similar option.
  4. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    If you don't run oversize then no problem. How much of your 2014 freight was oversize? You can figure how much revenue you will lose going with a rolling tarp.
    If I was doing regular flat loads I wouldn't hesitate to put one of these on my trailer. I think the US will follow Europe's lead and mandate rolling tarps in the future.
  5. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    We love our Roll Tite system! I will never pull anything again without one!
  6. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    There are plenty of legal loads that won't fit in a Conestoga. Good luck getting anything over 100" wide inside some of them. You have to be pretty bold to trust a forklift operator to load anything over 45' long into them, since when opened, they still cover a few feet of deck, so long pieces have to be swung in under the tarp.
  7. Salted
    96
    22
    May 23, 2014
    There is one that rolls off the trailer on an extension so you can load those type of loads.
  8. blessedman
    blessedman Light Load Member
    297
    230
    Feb 15, 2013
    Doniphan, Mo
    One would be nice if you haul a lot of tarp loads BUT I have seen many loads listed in the e-mail load list I get that are not oversize but forbid the use of them.
    Just this week I received an e-mail concerning a load of railroad ties which said NO conestogas or sliding tarp trailers.
    Don't know why. Maybe they have damaged one in the past and don't want to chance it again?
  9. Salted
    96
    22
    May 23, 2014
    Thats the thing. This new system allows you to completely remove the sliding rail system for those certain loads. However you would have to take it off and leave it at your "garage"
  10. Ubu
    1,252
    1,178
    Aug 25, 2012
    Most advertize a full 102” capacity as the taping system can be wider the 102” and still be league. I know that the Fasttrak system says it has a 104” standard width and comes in 7’3” or 8’2” standard heights and you can order custom heights up to 13’6”.
    Fasttrack offers a Max-Width kit that allows for up to 104” inside width if the standard width is not enough
    The Fastrack system also has a run-open package that allows you to lock the tarp in the open position while driving allowing for any oversize freight.
    All their options can be seen at http://www.fastraktarps.com/fastrak-upgrade-options/. Other manufactures may offer similar add-on's.
  11. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    Wichita, KS
    I'll argue that, on our QuickDraw systems we can actually load freight 103" wide and still get them to close just fine. Ours are all 108" outside since the law allows for tarping systems to extend beyond the 102".
    As for loading longer freight, again not an issue, roll the tarp to the front, have the forklift line up behind it then back up with the truck to get the load inside the front.
    Cetane+ and The Admiral Thank this.
