"Change fuel filter" warning on dash?
Discussion in 'Volvo Forum' started by 6cuda6, Jan 6, 2021.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    OK i know this seems obvious but what exactly does this indicator "change fuel filter" mean? One would assume that the filter is plugged or restricted and is pushing pressure "high" but it appears that changing the filter does nothing.
    Do it simply mean the pressure is to high or to low and not in specification?
    What have others done to resolve the issue?
  3. AModelCat
    164,802
    Is there a maintenance tracker in the display? Could just need to be reset.
    D.Tibbitt and 6cuda6 Thank this.
  4. 6cuda6
    259
    176
    Oct 9, 2020
    Honestly have no idea...thanks for the idea...ill give it a look.
    D.Tibbitt Thanks this.
  5. AModelCat
    164,802
    Pretty common in heavy equipment. No idea if that sort of thing has made its way into trucks. I try and avoid all trucks that aren't mine lol.
    Coffey and D.Tibbitt Thank this.
  6. Deadwood
    Deadwood Heavy Load Member
    789
    2,296
    Dec 24, 2016
    If it’s under 20 degrees it could mean your fuel is gelling.
    OhNoTerry, flood and D.Tibbitt Thank this.
  7. D.Tibbitt
    157,178
    What truck do u have
  8. 6cuda6
    259
    176
    Oct 9, 2020
    08 volvo 670 with a D16
    KB3MMX and D.Tibbitt Thank this.
  9. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    that indicator means there is a fuel pressure drop in the truck, this is the way truck is programmed to give you change fuel filter light, possible filters getting plugged also low pressure in the fuel system, possible sucking air somewhere also possible injector problem. so in laymans terms something is going on with you fuel system, this is all the truck is trying to let you know.
    magoo68, KB3MMX and 6cuda6 Thank this.
  10. Weiboy718
    Weiboy718 Bobtail Member
    47
    34
    Jan 25, 2017
    I had a similar problem just yesterday. Check fuel filter light came on, pulled over and checked whatever I can noticed nothing out of the ordinary but moments later my truck started to sputter and another check light came on for the after treatment shut off valve.
    Had it towed to a shop and they found my drivers side fuel tank has plenty of diesel but the passenger side was empty. Turns out the breather hose on my passenger side fuel tank was clogged and the diesel wouldn’t return back to the tank. Might be worth a look.
    86scotty and 6cuda6 Thank this.
  11. 6cuda6
    259
    176
    Oct 9, 2020
    Will do and easy enough....thanks
