Changing antenna shaft length
Discussion in 'CB Radio Forum' started by sbaumann14, Feb 28, 2020.
  1. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Will changing an antenna shaft length affect the SWr? Currently have a browning antenna with an 18 inch shaft length that I want to go to a 24 inch shaft to get it up a little higher
  3. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Yes, because you're not only changing the physical length of the antenna, but also the electrical length of the antenna.
    jessejamesdallas Thanks this.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yep...you'll need to re-tune.
    Diesel Dave Thanks this.
  5. sbaumann14
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Ok....have weekend off. Will do
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Its likely gonna be close to same over all height but coil will be higher...
    Be sure to use a beefy mount and stud...Check it closely every week and after heavy winds...Might be there one min and gone the next...
    Another good idea is to use a smidge of antisieze where any two points connect..
