changing engine problem
Discussion in 'Western Star Forum' started by rfkennon, Feb 19, 2021.
  1. rfkennon
    rfkennon Bobtail Member
    Feb 19, 2021
    in western star tractor, changed engine from cat 3406e to N14 cummins.
    trk will run only if you use starting fluid. cant get it to crank or run without.
    any idea what may be problem?
    Dino soar Thanks this.
  3. AModelCat
    164,721
    Could tons of things. Wiring wrong, wrong ECM setup, incorrect fuel line connection.
    How are you able to run it on starting fluid if it doesn't crank?
    Bean Jr. Thanks this.
  4. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Is that an n14 mechanical or electronic?
    If it is electronic how did you go about changing the wiring?
    Rideandrepair Thanks this.
