Changing from a slider to a fixed 5th wheel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by WallyGator, Dec 16, 2009.
  1. WallyGator
    WallyGator Medium Load Member
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    im changing from a slider to a fixed 5th wheel and don't know the Right way to set it up. how do you chose. i would think it would be in the same place? any help would be appreciated.thanks Walt
  3. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Wally I may be outta place by saying this since I don't know what your pulling anymore, but I would just keep the slider. But if you do have to swap I would get the trailer your gonna pull and load it legal and set your slider to the point where your right on the money for 12,000 and then mark it or take a measurement from a fixed point. Then go and swap to the fixed fifth wheel...thats the best I can say.
    WallyGator Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    I agree!!!
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Most of ours are fixed, if you pulling a spread axle trailer you never slide it anyway.
  6. jeepskate99
    jeepskate99 Road Train Member
    I haul tankers. We don't slide ours EVER. Unless of course we want tickets for not being bridged right.
  7. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    the problem is im selling my 95 in 4 months and can get a fixed for$150.00 and a slider for $450.00. I pull a 53 dryvan now and have it set right now but a friend told me to set it forward from where it is now.Im to lazy to pull the plate off its a holland with the pins on the inside.thanks for the replys so far. keep them coming.thanks Walt
  8. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    Well most of ours are set ahead of center by at least 4 inches. Another is almost all the way up to the front drive axle. The one I drive is a slider and is as far forward as I can go without the frame hitting on my flat with an 18in pin. If I was pulling a tandem axle van I'd want the slider. But like I said most our trailers are spreads so scaling out isn't an issue.
  9. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    Both ours are fixed (T-600, T-800), they are set so the kingpin is just about directly over the back edge of the rim on the front drive axle. The 800 was that way when we got it, it used to pull refers, seems to work fine with our hoppers too.
  10. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    well fixed it is..now to get the mounting bolts off.. thanks for all the replys.wish it wasen't raining and i have had the flu for two weeks. oh well a lot cheaper then $100.00 per hr.LOL Walt
  11. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    On occasion I have to pull a doubles set...so they set my 5th all the way back...it really sucks with the 53 vans, as the steer axle is never over 11,400 lbs...a bit soft in steering but I tend to have shippers load me heavier in the front, which gives me the advantage of having more options with the tandems (not spread of course).
