Changing tire size...
Discussion in 'Ask An Owner Operator' started by Babyboy1968, Sep 10, 2023.
  1. Babyboy1968
    Babyboy1968 Bobtail Member
    My question to the truckers out there is I have 3.90 rears .285/75 22.5 tires wanting to go to 11R22.5 .how much of a drop in gear will this give me.looking for better fuel mileage.currently getting 6 mpg.s. I do have 11R 22.5 on the front.12.7 Detroit 60 series
  3. snowwy
    snowwy Road Train Member
    20,567
    13,293
    Jul 6, 2009
    The fronts won't matter since they have no ties to the power train.
    Have you verified your odometer accuracy to a GPS app? Your odometer and speedo might be reading a little higher then GPS. Causing you to rack up more miles then actual.
    I could be wrong but the truck may have originally came with hi pros. Instead of low pros.
    Only time I've seen low pros is on drop axles.
    Others may have seen different though.
  4. abyliks
    abyliks Road Train Member
    3,924
    9,187
    May 2, 2010
    ludlow MA
    What’s the door tag say? I’d be surprised if someone geared the truck that short on low pros and not 11 or 12 22.5s but people do weird sht sometimes, 3.90s are about perfect with 11 24.5s though and a rtlo trans
    North Pole Nightmare Thanks this.
  5. Rideandrepair
    17,356
    56,314
    Aug 8, 2015
    Probably close to a 370. Check the calculator
