charged trailer's?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 1catfish, Dec 8, 2011.
  1. 1catfish
    1catfish Road Train Member
    1,494
    778
    Jul 18, 2010
    i would like to convey a lesson i learned the hard way.whenever you are told you need to use intransit heat be mindful that the little tag on the front of the trailer saying this trailer was charged on the day of pickup is not always true....arghhh.yes i hooked up opened my valves to check for leaks and before i knew it most of my anti-freeze ran out on the ground(dirt lot).arghhhh again. there's a little valve in between the trailer tandems that was open, i had to slide up under the trailer just to close it. and then break out the gallon jugs to refill what was lost. don't believe any tag's on front of trailer when picking up. till you've checked it for yourself. just one experience that i remember when doing tanks.:biggrin_25523:
  3. 1catfish
    1,494
    778
    Jul 18, 2010
    i noticed that schneider used the kind of pump that wasn't shaft driven, so i don't know it looked like it ran off hydralic pressure. but the pump we used was a roper pump and ran off pto shaft application. i remember the first load i ran to des moines out charlotte, the first thing dispatch said was make sure the pump is not froze up before you kick the pto in gear upon unloading, i learned that a pipe wrench works real good on that flat sided shaft. nothing like using a pump with snow on the ground. good times..:biggrin_2559:
  4. 1catfish
    1,494
    778
    Jul 18, 2010
    just curious, have any of you tanker driver's have a customer that upon delivery they said it was okay to air off a flammable load with compressed air instead of nitrogen? you all know what they told you in safety meetings. big no no.... i ran into to that problem in n.j. very unsettling. i know they told us that for a reason. so i tried to make all the phone calls i could make to safety, basically it came down to get them to sign bills and stand out of the way....sheeshhhh.:biggrin_25513:
  5. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Yes Catfish....and no, never, no way. Refused to deliver. Took a lot of heat from the carrier and the customer and didn't get paid but I'm here to write about it.
    That's my line in the sand...safety for profit...... not going to happen.
    1catfish Thanks this.
  6. seabring
    seabring Road Train Member
    1,844
    1,883
    Apr 24, 2011
    Thanks for the post 1catfish , could you maybe go in depth about how the intransit heat works on a tank? I dont have any experience with this type of trailer but would be interested to know how it works and what products you haul with them.
  7. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    Most tankers have fluid lines that run underneath the tank. There are 2 connectons on the front of the tank and usually a steam pressure release valve on the back. They can run steam through those lines to heat product. Today I unloaded a wax that becomes a solid at 130F. It was loaded at 180F the day before. That is an example of a product that might need to be steamed to heat it up.
    The tractors are equipped with quick connect hoses that match those on the trailer. To run intransit heat the trailer lines must be charged with antifreeze just like what you run in your truck. You actually hook the cooling system of your engine to the tank and it circulates warm engine coolant around the tank as you go down the road.
    kw9's rock, 1catfish and Big Don Thank this.
  8. mustang190
    mustang190 Road Train Member
    2,882
    6,213
    Jan 18, 2011
    Florida Panhandle
    Always carry a few gallons of pre-mix coolant in the side box.
  9. 1catfish
    1,494
    778
    Jul 18, 2010
    yea, that old truck i was driving i carried at least 3 or 4 gallons jugs of coolant just incase.
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I haven't dealt with any kind of loads like you're talking about but safety is the same for all of us. A very good training movie to see is the "Charlie Morecraft Story". All he does is talk about what happened to him when he got burned real bad the day before his vacation. It was in a refinery but on a valve that everyone knew was not working like it should have. He took the word of other workers and that is what happened. The message he conveys is it's you that will get hurt so don't take any short cuts and work for you and not them.
  11. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    I used to deliver to the General Motors foundry in Defiance Oh. The product was a GP resin they used in the casting process and it carried a flammable placard. It was a thick, sticky goop that was a mixture of methanol, formaldehyde, urea and a few other equally nasty things. The unloader always tried to get us to air it off because he didn't want to roll the hoses after unloading to get all the goop out. It was a center drop trl and it took 4 3' hoses to unload. The product just wouldn't move thru a 2" hose. It was a pain to do and he b*tched about it the whole time. I told him if the only way we could legally use pressure to unload was to use nitrogen. He didn't understand why.
