Chasing gremlins
Discussion in 'International Forum' started by ActionJackson350, Feb 17, 2021.
  1. ActionJackson350
    ActionJackson350 Bobtail Member
    11
    Dec 19, 2018
    Anyone with the experience to tell me how to run a new power wire to my ecm step by step would be great! My truck randomly shuts down with electrical fault spn 2000 -9 and -19.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    It's not that simple. The ecm has 5 separate power feeds, and 4 grounds plus an ignition input. You just don't run a new wire to it. Spicing into the harness is not recommended unless absolutely needed. Your engine could be shutting down due to loss of ignition or battery power or something else. Those codes are not from the engine, but from the body controller reporting loss of communication with the engine. The main engine power feed comes from the mega fuses at the firewall. Tucked in the wiring around the air cleaner is a 25 or 30 amp fuse for the ecm. Check it for corrosion. Run the engine and wiggle the wiring gently to see if you can induce the problem to hopefully find a bad spot in the wiring. Engine ignition feed fuse is 5 amp and located in the fuse/breaker panel in front of the passenger seat. Give it wiggle too.
    xsetra Thanks this.
  4. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Like Heavy said. Could also be on the ground side. In your other post you said you weren’t electrically inclined so best be left for a pro to diagnose and repair.
    Heavyd Thanks this.
