I have a 2006 volvo 780 automatic. The message board says check engine ecu. The truck will not start. 30 amp fuse on battery is blown. A new one is blown too.
Any clues guys?
Check engine ecu truck doesn't start help!
Discussion in 'Volvo Forum' started by gotmovers, Mar 1, 2012.
disconnect small (front) engine ecm connector. If fuse blows - rewire engine ECM power supply. If not and blows when you connect ECM power supply connector - engine ECM is damaged with overvoltage ore wrong polarity. I used to repare faulty ECMs with this kind of damage
Ouh.... is it ISX - if yes - follow the previous message, if Volvo D13 - some other issues with internal ECM damage
Had the same problem....check wires from where they attach to battery. Mine had a kink in wire, yours might too. If fuse is blowing, your shorting out somewhere in that wire that leads from battery to ecm
Got ecu unit on volvo 780 2007 how do I get started to get to a shop.on 24west ILLINOIS
@Mrasheed You realize you posted like 4 times on a 7 YEAR OLD THREAD?????
go call a tow-truck...dang itSnailexpress Thanks this.
