Check engine light on cummins isx 2012 peterbilt
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jonathan Hunter, May 15, 2015.
  1. Sportster2000
    Sportster2000 Road Train Member
    Jan 5, 2008
    1,480
    Thanks Received:
    886
    Indiana
    The only reason that I brought up the SCR was the fact that the SCR that Cummins brought out in 2010 had issues after a certain range of miles. They weren't as effective as they should have been and they started to replace them on trucks as they failed. It was a certain date range of when they were built that they had issues with.
  2. pop's
    pop's Light Load Member
    Feb 3, 2013
    54
    Thanks Received:
    16
    Yulee FL.
    take the pipe off an flush it out with water .that def will plug up the pipe if not cleaned out.
