Check engine, stop and oil light
Discussion in 'Freightliner Forum' started by Freightliner-2013, Jun 2, 2016.
  1. Freightliner-2013
    Freightliner-2013 Bobtail Member
    10
    Perfect answer, that exactly what going on , thanks bro , it's what the freightliner said and they fixed
  3. spyder7723
    spyder7723 Road Train Member
    15,468
    25,078
    Mar 31, 2013
    sarasota, fl
    Did you have them inspect the bearings to see how much damage you did while running it for a month like that?
  4. Freightliner-2013
    10
    I did not , I think I am going to stop again and ask for inspection, thanks
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I would say that you should change the oil sensor. My theory is that the oil shifting in the pan causes a slight pressure change and kicking off the bad sensor. That will cause the computer to shut down the engine.
    Freightliner-2013 Thanks this.
  6. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    It can be simple o-rings on the tubes from the oil pick up to the oil pump.
    QUALITYTRUCK Thanks this.
  7. Dave301
    Dave301 Bobtail Member
    I got the act problem and its crazy.
    Only people to touch it where DC Freightliner, doing a Clutch after Accident putting in an XY Shifter.
    I had then change Seal Between the Engine & Trans.
    Also they Plug a Leak Where A PTO used to be.
    I had the Shutdown #### happen one time 8m ago.
    Now it say oil is low by A Red Light a Noise.
    I you ignore by not pushing the Pedel, a Check Engine Light and Shutdown light come on.
    But if move a foot or two, or put it in Neutrel and hit the pedel its good after it hit 50.
    Got an Automatic too, Repair Are Crazy High.
    Also After they put in NewbXY Shift Accidently because the computer said so, it locks up in traffic 4-1.
    You can put it in N, then it reset to 1.
    Still Stuck.
    I turn the power of with a Swith it work perfect again.
    Freightliner Refusing to Pull it out say the gave it to me.
    Lol
    2009 Cascadia.
  8. Dave301
    Replace still.Beaping,Check Engine.
    O Rings pulled out where fine,a little hard. Also Replaced Oil Sesor.
    Only thing I didnt check was The ByPass Valve on the top of the Oil Filter.
    Of Course Freightliner Said it check it,then today said they didn't.
  9. RocketyMan
    RocketyMan Medium Load Member
    554
    339
    Jun 5, 2015
    That's why I don't like the eaton crap-O-shift-plus transmissions. They should really just stick with building manual transmissions.
  10. Used freighliner
    Used freighliner Bobtail Member
    What was the problem with your truck I have the same problem can you share
  11. B Mac
    B Mac Bobtail Member
    Yep!!!!
