Check out my tarp rack!
Discussion in 'Flatbed Trucking Forum' started by God prefers Diesels, Oct 1, 2021.
  1. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    I was sick of having to move my 8' tarps, and I'm getting rid of my bulkhead for a 3-door Merritt, so I needed some serious storage.
    Don't mind the welds. They're like my trucking skill - ugly, but it works. 20210916_115344.jpg 20210916_165839.jpg 20210917_113958.jpg 20210917_113949.jpg 20210919_160745.jpg 20210919_160752.jpg 20210927_164343.jpg 20210927_164401.jpg
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
  4. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    If you're curious, my machine is a Miller Multimatic 215. Has a 210 MIG side, an does TIG and stick. Has high frequency start, swaps between 110 and 220 by itself, adjusts heat automatically based on your stick-out, and will auto set settings based on material thickness, but you can override WFS and voltage with the dials. It's a beautiful machine.
  5. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    The door is 14 gauge, and the skeleton is 11 gauge. I've got 12 - 3/8 bolts looking up, and three more on each end for sheer strength. Also cut up a plastic mudflap for padding between the steel and aluminum.
  6. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Oh, I also fixed my dunnage rack. I underestimated how much of a beating it would take.
    20210916_115405.jpg 20211001_121713.jpg 20211001_121717.jpg 20211001_121725.jpg
  7. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Haul a coil and check out the cage operation, SHOULD be good since its only bolted up on ends ?, but ive had shorter boxes where the arch going away messes with the doors.
    Vampire, Nostalgic, D.Tibbitt and 3 others Thank this.
  8. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Bolted at the ends, and the middle. But the bolts in the middle, I only got "tight", so the deck could flex down onto the box. I also made the latch hole oblong so the box could flex up and down and I can still open it.
    But this is all theory. I won't know for sure until I put weight on the deck.
  9. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Fair enough, consider getting compressible rubber as your "washers" for the center bolts depending on what it does on your first couple runs
    OLDSKOOLERnWV, cke, staceydude and 3 others Thank this.
  10. Speed_Drums
    Speed_Drums Road Train Member
    1,029
    1,989
    Dec 26, 2014
