Check your fuel tank straps...
Discussion in 'Ask An Owner Operator' started by Justrucking2, Aug 11, 2018.
  1. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Get under those trucks and check those fuel tank straps folks. Especially if you have skirting and run in the winter months in the snow and ice. I have replaced four of them already, the last two are getting replaced today. They can rot out up under the truck, hit a bump and "SNAP". They are easy to install, and easier to inspect. Get'er done now before the snow flies. ;-)
    Rollr4872, Freddy57 and TIMPTE 527 Thank this.
  3. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,021
    9,859
    Oct 18, 2010
    NW Indiana
    One of the advantages of having a minor oil leak at the oil pan for years. Kept an oily coating on everything to defeat that God awful stuff they put on the roads these days.
    My straps are getting shaky on top because of it.
  4. 201
    201 Road Train Member
    12,822
    26,404
    Apr 16, 2014
    high plains colorado
    We called that the poor mans rustproofing. In all my years, only had 1 tank strap break, on a R model Mack.
    Rollr4872, Tug Toy and Rubber duck kw Thank this.
  5. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Thanks for the reminder, I need to get under mine and take a look. Weather is nice, it's a great time to do it!
    Tug Toy and laaylor Thank this.
  6. JonJon78
    JonJon78 Road Train Member
    7,245
    43,249
    Jul 1, 2018
    What year is your truck?
    Tug Toy Thanks this.
  7. roadtech
    roadtech Medium Load Member
    391
    920
    Sep 4, 2010
    Northeast
    I had a strap break on a ch Mack and a 2000 Pete 379. Lucky I had ratchet straps with me both times to hold the tank up until I got back to the shop.
  8. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    So don't get the oil pan gasket replaced? It doesn't drip anymore, but everything stays wet down there
  9. Studebaker Hawk
    3,021
    9,859
    Oct 18, 2010
    NW Indiana
    I have replaced the pan gasket and it no longer leaks. I just didn't steam clean the chassis, left the residue there. I know guys who used to spray used crankcase oil on sections of the chassis they wanted to protect from the harsh chemicals now eating our trucks alive on the roadways.
    A friend of mine just had to replace the frame rails on a 1998 Pete 379 because of the corrosion damage caused by the stuff.
    Justrucking2 Thanks this.
  10. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    2008... Had two break on me going down the road here in Michigan, which is easy to do. Cheap Chinesium steel, never had this happen on any of my other trucks of similar age. Like everything, prices are up and quality is out the window. Truck manufacturers are trying to get all of the R&D monies back wasted via EPA regulations. On our backs.
    And of course the chemicals used on the roads in the winter seem to be worse on metal than the old salt. But the metal is still junk that they are using on these trucks, most of which I am sure was sourced in China. Just my opinion of course.
    Studebaker Hawk, Tug Toy and JonJon78 Thank this.
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    If new straps are needed I like to use epoxy under the strap area to slow or prevent tank leakage from corrosion
