Checking Detroit ser 60 TDC
Discussion in 'Freightliner Forum' started by Verdel, Jan 8, 2017.
  1. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    Which way is more accurate to check TDC on cylinder No 1:
    1. Remove injector 1 and put a dial indicator in the hole.
    OR
    2. Do not remove injector No1, but rotate the engine by hand to get the No. 1 piston at TDC. Do this by installing the crankshaft
    timing pin J 45947 into its bracket and the barring engine over by hand until the timing pin
    drops into the locating hole in the crankshaft, the engine is now at TDC on cylinder No.1
    https://www.apexinds.com/tools/M30153.html
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Not going to get any more accurate then step #1
    Verdel Thanks this.
  4. Verdel
    599
    135
    Oct 26, 2013
    Ok, I agree, but just installed new injector in cylinder No1. Now if removed, I have to change the O-rings and run the overhead again.
    Is No 2 method so bad or what?
  5. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    What are you trying to do exaclly
    Verdel Thanks this.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Well u asked what was more accurate and i gave you an answer.
    The other method is good also.
    Verdel Thanks this.
  7. Verdel
    599
    135
    Oct 26, 2013
    Ha-ha-ha. I was hopping the both methods are equal :))
  8. Verdel
    599
    135
    Oct 26, 2013
    I am trying to check the cam timing. Cyl No 1 at TDC then I will measure the Injector Cam Roller Lift at TDC.
    Here is the spec.
    The truck runs not at full power on hills. After replacing: injectors, vpod, fuel return line valve/regulator, fuel pump, the turbo is good - motor is getting up to 40 psi. The last ting is timing.
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Did you check air p.s.i. output to vpod? The regulator valve is on top of driver side air tank, has 2 yellow lines. The smaller one is the line that supplies air to vpod. Part# GTD223455V at Freightliner. It is a $25 part and takes about 20 min. to swap if that ends up being your problem.
  10. Verdel
    599
    135
    Oct 26, 2013
    Why check the vpod, if I am getting up to 40 psi boost?
  11. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    oops. better clean my glasses.
