checking for boost leaks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ezrider_48501, Apr 13, 2018.
  1. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    just a quick video on how to check for boost leaks and a simple home made tool to do it with.
    Shock Therapy, SAR and Bean Jr. Thank this.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,940
    Mar 30, 2014
    I guess you need a new CAC.
  4. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    What's the numbers off the pvc pipe and the brass cap and where did you get them? I'm assuming its a 4 inch pvc? I've been wanting to build something like this to test CAC's. Thanks for the videos as always!
    Ezrider_48501 Thanks this.
  5. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    mine is actually 3 inch yours being a cat is probably 4 inch. i just got the stuff from the plumbing department at menards, made sure that i had a boot that would fit the inlet side of the turbo then i carried the boot into the plumbing department and milled around till i found a combination of stuff i thought i could make work. my original plan was to get a piece of metal pipe weld a piece of flat steel on as a cap to drill and tap. but i could only find drain pipe big enough in pvc so finding the brass clean out caps was kinda the ticket for me.
    i did notice they had the brass clean out caps in both 3 and 4 inch.
    SAR Thanks this.
  6. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    yeah i guess so. i was actually trying to diagnose a chirping sound that i could only hear under high boost when i did that test, turned out to be a bad exhaust manifold gasket. still have that cac in the truck. it bubbles a lot but it still took a min or two to leak down when you shut the air supply off. considering the amount of cfm your flowing at full boost and max rpm the cfm/leak ratio on that is pretty small. but yeah ill need to be planning to replace the cac in the near future.
    Bean Jr. and SAR Thank this.
  7. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    SAR and Ezrider_48501 Thank this.
  8. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    very useful information. thanks for posting.
    SAR Thanks this.
