Checking tires
Discussion in 'Questions From New Drivers' started by Jubal3, Jun 19, 2016.
  1. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    OK, I feel like an IDIOT for asking this, but I honestly don't know a darn thing about tires other than tread depth and (checkable) tire inflation, and obviously, bead and sidewall issues.
    I was never taught more in school, nor have either of the two trainers I had ever really explained more to me.
    I do my pretrip, I'm checking inflation levels on my drives and steers.
    I go to my tandems, well, they have auto-inflate, so I bang 'em with a thumper, trying to see if there's a drastic difference in feel or sound.
    BUT... EVERY time I start rolling, I get a warning light about tire pressure on my tandems for 1-5 minutes, (Depending on the trailer) which then promptly goes away, even AFTER I thumped them and they all sound the same.
    So I'm GUESSING, that this is a sign of a very slow leak, that goes away when the auto-inflate does it's thing. I really HATE guessing.
    Any suggestions? Anything important I missed on tire inspection? This is the only area of the truck I feel wholly unqualified to judge, and it just makes me feel dumber than a rock. But I honestly don't know what to look for other than obvious large divots, holes and nails and gouges in the sidewall, plus beads that look misshapen or bulges in the sidewalls.
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Trust the tire pressure gauge. TPI systems that report to an in-cab display often have faulty sensors. Either it is low or thinks it's low. And as it heats up it gets satisfied.
    I assume we're talking about a trailer tire? If these have auto-inflate I don't know why they'd have a TPI system
  4. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    You're not dumb.
    Inspecting your tires even with a inflation system brings you to the head of the pack already.
    That light in the morning or at a trailer you just hooked up to is usual.
    The air in the system of a parked vehicle drops, some more, some less. When building up pressure in the morning, the inflation system just indicates of a inflation in progress. It could take up to 10 minutes.
    Checking the tires only for leaks might not be sufficient. Sometimes the system itself has a leaking connection which could cause trouble.
    Keep on doing your job. Inspect your equipment every morning and every time you hook up to another trailer.
    An old DOT inspector once said "do your walk around in the morning and you're off the hook." It's true to this day with me.
  5. okiedokie
    okiedokie Road Train Member
    14,108
    112,472
    Jun 13, 2011
    PNWET
    Take a look on the inside of your tires as well.
    RDBG Thanks this.
  6. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    You can also check the hub temperatures using an infrared gun. Hot tires equal bad things coming.
    flood and RDBG Thank this.
  7. RDBG
    RDBG Medium Load Member
    309
    692
    Jun 23, 2016
    I'm in school right now myself. I feel I have the pretrip down pretty well beyond what they want to see for a road rest (clutch the pearls I know) but I've asked a similar question of these instructors and everyone dances around it.
    Sufficient tire tread and inflation no separation or debris between the rims no rust streaks or signs of loosening from the lug nuts no visible damage to the rims no leaking from the hubs valve stems centred and capped. It sounds nice for a licence examiner but riddle me this. Surely you don't rely solely on a hammer a club or a boot to tell you what's in that tire.
    Don't get me wrong I'm all for having a good melee weapon handy at your disposal for the occasional unruly lot lizard or persistent bum but doesn't anyone use a tire gauge?
  8. Wooly Rhino
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    Love's has a lane dedicated to checking your tires. The first time is free. That is the time it is well worth the price. The attendant will come out and check the pressure in all your tires. Follow him around and ask him what he is checking for. It is his job to sell you new tires so he will be happy to point out every little defect and things that might be correct now but could go wrong in the near future. You can also talk to any of the tire people at a professional shop. People love to pass on knowledge.
  9. A Bug
    A Bug Heavy Load Member
    964
    1,997
    Mar 15, 2014
    Sevierville TN
    The auto inflating tires do not have the valves open to gauge. You would have to unscrew the inflation kit first then reattach when done on each tire. Much more efficient to just kick the thing!
    RDBG Thanks this.
  10. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    I have one.
    But what's normal/safe temp for the hub or tires.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I have the Hendrickson Tiremaxx Pro inflation system on my trailers. It has two regulators on it. One for how low the pressure is, the other for how high the pressure gets. They are set 10 psi apart to keep the tires in a pressure range. During normal operation during the day when temperatures get hotter, and tire pressure increases it will bleed off some of the air.
    Then when you park over night and everything gets cooler the tire pressure now will be low in the morning. So you see the light come on until it gets things back to normal.
    Thumping the tires is still a good idea to confirm that one of the tires isn't down.
    akfisher Thanks this.
