Chirping from air governor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by J3DIKing, Jul 8, 2024.
  1. J3DIKing
    J3DIKing Bobtail Member
    15
    4
    Nov 13, 2023
    Hello all, I’ve recently replaced my dryer and air governor and everytime the dryer purges air there’s a chirping sound coming from the air governor. When I back off of the set screw from the governor the chirping goes away. Parked or driving the pressure slowly drops to around 100 the chirping goes away and starts to build air again. I’ve noticed the chirping will go away immediately if I disconnect the line that runs from the governor to the dryer. Not sure if it’s back feeding air and slowly releasing pressure that way or not are there any thoughts why this could be happening?
  3. MRMTRANS
    MRMTRANS Medium Load Member
    408
    441
    Apr 28, 2015
    One of the times I changed a governor for a S60 Detroit, and I had a high pitched whistle for about 2 seconds before the governor would cut out. I figured out it was the gasket for the governor and learned from my mechanic that this was not uncommon. The noise eventually went away.
  4. J3DIKing
    15
    4
    Nov 13, 2023
    Fair enough today’s my first day running it like this so I’ll keep on trucking. Thank you.
  5. J3DIKing
    15
    4
    Nov 13, 2023
    Fixed. The 3-4 inch hose in the Air Inlet Port had a small rip on it. ‍♂️
    BoxCarKidd and Lav-25 Thank this.
