Choice program SNI IC's with sleep apnea
Discussion in 'Schneider' started by free2frog, Oct 20, 2015.
  1. free2frog
    free2frog Medium Load Member
    437
    155
    Sep 15, 2009
    Indianapolis, Indiana
    Just curious if I were to apply for the choice program, and I have sleep apnea as long as i bring my compliance download from my machine is there an issue, also for any IC's with sleep apnea is there any discount on supplies, I know 5 years ago as a company driver you got stuff for next to free with there insurance, but as a contractor is there any discounts?
    FatDaddy Thanks this.
  3. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    As long as you have an approved machine you're fine. When they set up my orientation they wanted to know what machine I was using...it was on their approved list and all I needed to do was bring in my downloaded data and good to go
    free2frog Thanks this.
  4. free2frog
    437
    155
    Sep 15, 2009
    I still have the same machine as when i was a company driver there so hopefully if i go this route it wont be an issue.
  5. tazman74
    tazman74 Light Load Member
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    No discounts you are on your own. I get most of my supply's from cpap.com
    Ok big boy and free2frog Thank this.
  6. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    I wonder why IC's are required to comply with company driver standards for this?
    DOT does not require they only suggest the minimum compliance standards SNI sets the company driver policy as if you are 1 and the same.
    I understand it's company policy but to have the exact same requirements for Sleep apnea would lead one to believe IF they went tobacco free they would require IC to be also. Or even footwear!
    I'm not saying those who benefit from the cpap machines should not use them I am just curious as to why there's not any stink about IC being held to company driver standards on this as well as other issues.
  7. stevep1977
    stevep1977 Road Train Member
    3,704
    22,673
    Dec 23, 2010
    Chicago, IL
    They don't even enforce it unless you voluntarily submit to the program. I needed my cpap data report for my medical card renewal and I contacted the service that Schneider uses in Houston to get a print out of my report. At that point they registered me up and I was then subject to Schneider compliance.
    I probably just slipped through the cracks but if I knew/had the correct software to produce my own reports Schneider wouldn't have even caught on
  8. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    Did SNI cover you on the compliance monitoring? Or were you billed?
  9. tazman74
    254
    119
    Feb 27, 2013
    Albert Lea, Mn
    I use sleepyhead. Just google it.
  10. RStewart
    RStewart Road Train Member
    3,169
    5,055
    Aug 21, 2015
    Norman, OK
    Pick & choose your battles. This one isn't worth it. It's not a big deal to submit the compliance data sheet.
    Didn't cost me anything to have someone print it out for me to bring to orientation & I didn't do it through SNI.
  11. FatDaddy
    4,314
    10,375
    Dec 23, 2008
    I thought I responded to this already so maybe I put it in the wrong thread. Lol.
    Anyway this isn't just Schneider. I've worked as an IC before and still had to comply with their apnea regulations. Not a big deal for me though.
