CHS 71 and much more codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Angry Ed, Jan 3, 2020.
  1. Angry Ed
    Angry Ed Bobtail Member
    Hi there. I have cascadia 2012. Trying to move from parking after truck was off for the night and found a lot of codes:
    1)000 000625 14 son
    Engine #1-proprietary data link special instruction
    2)061 003720 15 spn
    Exhaust emission controller-no text available, data valid but above normal
    3)061 000110 9 spn
    Exhaust emission controller-engine temperature abnormal update rate
    4)061 000108 13 spn
    Exhaust emission controller-barometric pressure out of calibration
    5)061 000171 13 spn
    Exhaust emission controller-ambient air temperature out of calibration
    6)061 000513 9spn
    exhaust emission controller-actual engine-percent torque abnormal update rate
    7)061 000190 9spn
    Exhaust emission controller-engine speed abnormal update rate
    8)061 520231 13 spn
    Exhaust emission controller-no text available. Out of calibration
    9)exhaust emission controller - after treatment 1exhaust gas mass flow abnormal
    10)061 520232 9spn
    Exhaust emission controller-no text available. Abnormal update rate
    11)071 520919 5spn
    Chassis controller #1-no Tex available. Current below normal or open circuit
    12)000 000191 9spn
    Engine #1 transmission output shaft speed abnormal update rate
    13)000 000524 9spn
    Engine #1-transmission selected gear abnormal update rate
    14)000 002900 9 spn
    Engine#1 - transmission engine crank enable abnormal update rate
    15)000 000973 13spn
    Engine #1 -engine retarder selection out of calibration
    16)000 003696 13spn
    Engine #1- no text available. Out of calibration
    17)003 000070 14spn
    Transmission #1-taking brake switch special instructions
    18)003 000639 14spn
    Transmission #1 -J1939 network #1, primary vehicle network special inspections
    all gages down:
    Oil pressure, water temp, trans temp, def level and RPM.
    Competer (on dash) checking system and (sometimes) everything go back to normal for seconds then again. Can’t drive more than 2-4 m p/h.
    Please advise.
    P.s. rain
  3. Angry Ed
  4. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Check your plugs going in to the ecm. I think thats where i'd start
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    datalink is shorted or something wrong with it .
    spsauerland and Working2party Thank this.
