cigarette lighter cb adapter
Discussion in 'CB Radio Forum' started by germster, Mar 14, 2018.
  1. germster
    germster Bobtail Member
    I just purchased a used 2005 extended cad Silverado
    It has A nice CB Aerial antenna attached
    I found the Antenna plug near the fire wall but cannot find the
    wire from the fuse box.
    I think the last owner had a cigarette lighter cb adapter
    I read to use such an adapter the cb must have a 3 point plug
    What cb should I buy for occasianaly use on trips
    And where can I get a compatible lighter adapter
    Thanks
  3. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Personally I haven’t had much luck with running the power wire to the fuse box, you still run the risk of getting electrical noises just like using the cigarette lighter. I didn’t realize this till now, but Walmart sells a cigarette adapter with the wire and a three pin connector for your radio. I wouldn’t use the 15 amp fuse it comes with. All you need is a three amp fuse for a 4 watt radio. The radio already comes with a 2 amp fuse. As far as a radio for occasional trips, you can’t go wrong with the Cobra 25LTD or a Uniden PC68xl.
  4. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    Find a truckstop that carries this brand.
    Then look for the heavy duty lighter plug.
    Mine has 12 gauge wire.
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Run it direct to battery with correct wire ga for the length req and applicable fuseable link..
