I have a 2010 Freightliner Cascadia and my city horn stopped working and it's time for my Federal Inspection. I looked for a fuse but I don't see one labeled horn can anyone help?
City horn want work can anyone help
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Tljtlj, Aug 30, 2017.
This is kind of old school, but it is a good place to start. Did you pop the button of the steering wheel? If it is a round disk in the center, you can pop it off and check the contacts. You may have a broken contact, (a small flat piece of metal that would connect when you push the button) You may be able to gently bend that piece so it makes contact. Good luck!
scythe08 Thanks this. -
Unplug the horn and insert a 12v test light between wire and good ground, then have someone activate the horn while you observe test light, or vice-versa. If the lights illuminates, replace horn, if no illumination then find location of power loss to horn. Sometimes the horn will fail and short, blowing the fuse.
Cottonmouth85, mhyn and scythe08 Thank this. -
Cottonmouth85 Thanks this.
girlsdrivetoo and mhyn Thank this.
