Clamp on style lumber carrier
Discussion in 'Flatbed Trucking Forum' started by SHC, Jul 13, 2012.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I am looking for a clamp on style lumber carrier. I can't drill holes into the frame of this trailer, so that's not an option. Anyone have a link or a name of a manufacturer???
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    They make a clamp on lumber carrier? I would think that you should be able to fabricate one that attaches to the cross members.
  4. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I saw one this week on a flatbed but couldn't get him on the CB. Someone told me AERO makes them, so I'm going to call them Monday and see what I can come up with.
  5. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    I'm pretty sure Tarp Stop handles a belly box for flats, but I don't remember what brand or how it attaches.
    SHC Thanks this.
  6. Truck609
    Truck609 Light Load Member
    238
    197
    Dec 17, 2011
    Arizona
    Me and a friend made ours...pretty cheap, very simply and easily adjustable or removeable. Not sure how the whole PM thing works, but if you can PM me, I'll give ya a call or text pics or something.
  7. Truck609
    238
    197
    Dec 17, 2011
    Arizona
    First time posting pics....not sure how this will come out, but here goes.
    2012-07-15_15-13-58_53.jpg 2012-07-15_15-14-06_330.jpg 2012-07-15_15-14-23_526.jpg 2012-07-15_15-14-57_564.jpg 2012-07-15_15-15-53_978.jpg
    Just use good tubing stock, not that thin walled stuff. Also, make sure you use grade 8 bolts. There are two bolts on each rack/bar, four total that hold everything. Make sure to use a buffer of sorts (I used old strapping) between the steel and aluminum. Also, this one was an experiment and I got greedy making the much larger than needed drop in the rack. I carry a full set of V-boards (made of 2X4's) and 10 4X4's on these racks with plenty of room left over for more. The other set my buddy made did not have the drop, just straight bars.....no welding required. Simple princicpal really, just sandwich the trailer flange. Hope these help.
    Jumbo and SHC Thank this.
  8. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    That is a very nice setup you made. I want to find one already built, but if I can't I have a few idea's of my own, and one was building something like yours.
    The other that I have plenty of room between the frame rails underneath the trailer. It already has a crossmember welded in place to stop the backward movement, so all I'd need is a few metal bars clamped on to support the weight and then something to stop it from coming forward when on the binders.
  9. Truck609
    238
    197
    Dec 17, 2011
    Arizona
    At the time that I made this, I was still running Cali. Cali has this thing about securing your dunnage with two securement devices with a WLL rating. So, long story short, this is a very simple dunnage rack that will hold anything (occassionally I have a ladder in there as well) and everything is secured with two, two inch ratchet binders, so you don't have to worry about forward movement.
  10. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
  11. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
