Cleaning a wheel end seal MESS!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Scrapper, Feb 12, 2012.
  1. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    So I was on a thread started by catmech2 and got to wanting to ask this but didn't want to steal his thread.
    What ways do you guys use to clean up the spindle, hub, drum, shoes, hardware etc...when a wheel end seal goes out and covers the world in the nasty cooked oil? I think most of our time spent changing the bad seal is spent cleaning up the mess it has made. Have gone through countless cans of brake cleaner...lol.
    Normally start by scraping the old stuff off. I let my bearings and misc hardware soak in diesel while I work. That way they are clean when I pull them out and can easily inspect them. I use a large folgers coffee can. It will hold it all. Once I pull it out of the diesel I lay it on clean paper towels or rags to inspect. Once all is done I'll start reoiling and putting back togheter. I have used B52, brake cleaner, diesel to clean the spindle, shoes, drum and such....anything I use makes a mess...and you never really get it all off. You end up spending so much on cleaners and such. Have you guys found any tricks or tips on getting it all clean for remounting? I know alot of it will burn off once the seal is fixed. But there HAS to be a better way. I could probably psi wash it the best I can before bringing it in...but you do not have that luxury most of the time. Then when you are hurried...you have water to deal with then.
    Just wondering what you guys do or have done in the past...what worked well...what didn't.
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    you already said it but, psi washer on the rearend, hub,drum and brakes, then scrap everything else off you can and hit it with brake cleaner. been in the mechanic business when not driving and that is the way I found is the easiest. just my .02
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I used paint gun filled with solvent, kerosine and brush. seems to me the best way. finally I used gas
  5. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    I scrape them best I can into a drain pan, followed by steam cleaning and sometimes use brake cleaner along with it. Solvents other than brake cleaner are heavily frowned upon these days for the cost and environmental issues, so not many options available.
  6. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    yeah wish we had a steam cleaner. Psi washer is nice...but without the heat the water hangs out for a while..then its in the shop all day.
    Seems like everyone is in the same boat...its a messy job...but somebodies gotta do it. lol. I have used compressed air. If your careful with aiming it works well. But one bad spray and your covered, or the truck is covered, or the floor is covered instead of keeping it localized. But it keeps from having the oil slick under the spindle. You know the one?.?.?...lol. Thats is made of grease, hub oil, etc...then cut with brake cleaners...whick allow the oil slick to expand...then a hand steps in it...spreads it just a little...so you slip on it. lol. :biggrin_25510: I carefully use oil dry under them...but its so dusty...I really try to keep from it as long as the hub is naked. Try to wait till I put the tire back on and everything is covered back up to put the oil dry down.
  7. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Without using any solvents the heat does the trick, but you still have a mess regardless. Even the steam cleaner won't do much but move it around until it gets good and hot with heavy soap.
  8. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Once the shoes have been soaked in the oil they are basically ruined so they get tossed. We have a parts varsol cleaner for the bearings. Scrape the bulk of the gunk off the best you can, then drag out the pressure washer. We'll pressure wash out the hub too. The water is heated to almost steam so it cuts the grease really well. Get the blow gun out and blow dry everything. A quick wipe and everything is pretty much #### and span. Very messy though, sucks!
  9. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    Heavyd...do you have a steam psi washer or are you doing something else? We do not have the excess funds now for a steam cleaner. Been trying to figure out a way to do something else. Yeah normally toss the shoes...thats hard when you can see so much more wear left in them. Hoping to get a parts washer when I'm full time at the shop. For now i'm using my folgers can...gives me a good excuse to keep drinking my coffee..lol.
    What chemical do you using in your parts cleaner?? I ask because I have used part cleaner in the past and some do not do the job of others. Chemtool is the best I've seen...but dang its high!
  10. Scrapper
    289
    83
    Jan 19, 2010
    Nashville, AR
    Really not trying to avoid the mess...its inevitable. Just picking your brains on what you do so I can save the shop some money on brake cleaner. I like things to be clean when I work...so I go through alot of stuff. The old mech would dive into messes and put the mess back together. I just can't do that. You can't tell me that when thats done you don't get some crude into what you just fixed. That drove me nuts when I used to work with him. Being that we are running poles and have loaders on nearly all our trucks its hard to keep everything clean when working...but I try my best. Seems repairs always go better when the equipment is clean.
  11. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    As expensive as any type of solvents are these days, it might be best to try to purchase an oil fired portable steam cleaner to do the majority of the cleaning. The cost could be similar or possibly even cheaper than purchasing all those solvents over and over again. Just my opinion.
