cleaning fittings
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by krazzyboi_44, Jun 12, 2021.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    298
    42
    Apr 30, 2008
    BAton Rouge,Louisiana
    Just curious but how often do you guys clean your fittings? And what do you use to get the job done?
  3. kemosabi49
    10,992
    47,985
    Jan 13, 2013
    SW Arkansas
    Clean them after every use. Let the guys at tank washes clean your fittings. In a pinch, I would spray them with high pressure at the terminal if there wasn't something really nasty on them.
    Just passing by Thanks this.
  4. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Every time I use them. When you drop the trailer at the tankwash, walk over to the bay and have them power wash that sucker. Once in a while I'll spread them all on the catwalk and spray some generic cleaner all over. Then wipe them dry and put them away. A bit like doing the dishes.
    kemosabi49 Thanks this.
  5. krazzyboi_44
    298
    42
    Apr 30, 2008
    What cleaner do you use? I know a couple guys use brake or carb cleaner after each use
  6. Just passing by
    1,176
    3,140
    Feb 25, 2017
    Brake cleaner sounds like a good idea. I was using housecleaning stuff... but I like the brake cleaner idea better.
  7. wis bang
    wis bang Road Train Member
    3,468
    4,128
    Jan 12, 2011
    Levittown, PA
    We always washed the fittings and pump together. I had all S/S and I carried it in a toolbox lined with a few rags, cleaned it all at the wash rack and hauled them home in my car in case dispatch stole my truck overnight. Our Macks had an extra battery box for fittings that could be locked but most of the rest had mild steel fittings so I guarded mine.
    That wash rack had a hose tub with a caustic detergent so I had to be on the lookout for guys who came from other tank outfits with some aluminum fittings. Also had solvent for dry bulk pipes so one could scrub aluminum without turning it black and ugly...
