cleaning the rubber floor
Discussion in 'Experienced Truckers' Advice' started by Samuelh, Aug 2, 2018.
  1. Samuelh
    Samuelh Bobtail Member
    36
    39
    Jun 23, 2018
    So I just got a new to me truck. 2017 international pro star. It's not nasty but the rubber floor is dirty. What's the best cleaner and method for cleaning it.
    I was thinking of getting a steam shark and using vinegar and distilled water.
  3. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,164
    Jun 3, 2018
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I just use soap and water with a good scrub brush.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Good ol' soap and hot water. Take a towel and some elbow grease. That will let you know what is dirt (earth, mud whatever) and what is stained and actually needs to be cleaned.
    Any sort of steam, pressure, etc will just get water all over the place, including inside the dash and the electronics there.
  6. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    i use Simple Green and several rags. leaves a nice scent for a while.
  7. Espressolane
    18,691
    117,159
    Those swiffer things. Don’t know whats in them, don’t think I want to. They will clean anything. Don’t walk on the floor for a few minutes so it will dry. Slippery when wet.
  8. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Or 409 with degreaser in it.
    Maj. Jackhole and Studebaker Hawk Thank this.
  9. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    vacuum or dry swifter for debris, wet swifter until the sheet isn't black anymore, then lysol spray and blue paper shop towels on the swifter head to kill the ebola. it boggles my mind how much grease there is stuck in the floor, that material texture traps grime bad. i got two anti-fatigue kitchen mats from sams now and put them down, and lay a towel down on top for "carpet" that can 1. actually be washed and 2. shows visibly how much poo you've tracked in and a stepping in.
  10. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Use 2 small buckets. One with a water and your preferred mild cleaning solution and a small scrub brush. The other with clean water and a big sponge to mop up the recently scrubbed areas, rinsing frequently. Work in small batches.
    Leaving excess cleaning solution behind tends to attract and hold dirt and grime.
    gentleroger, ZVar and Studebaker Hawk Thank this.
  11. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    That's woman's work. Pass cleaning concerns on to your spouse.:D
    Samuelh Thanks this.
