Closing the Gap: How much does it matter?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Sep 18, 2019.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I own a 2017 Volvo 780 with D13 and Ishift and since it has broken in and I switched to full synthetic oil and been blessed with a series of really light loads my mileage has increased from the mid 8s to 9.7. Volvos typically have a lot of weight on the front axle so I had the fifth wheel set all the way back and figured I was getting great mileage so just left it there after my last heavy load but now that I’m close to 10 I have decided to try for double digits. I was at 9.7 when I decided to move the 5th wheel all the way forward and am now at 9.8. Have any of you run this experiment to see how much of a mileage improvement can be attained by minimizing the gap between the cab and the trailer? I pull a 53 foot box.
    Intothesunset Thanks this.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Yes the gap makes a difference, If you don't have them yet might want to put some Airtabs on to. Thy definitely help to get that air flow around the trailer and give you better stability in the wind.
    Midnightrider909 Thanks this.
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    your trailer will make the biggest difference. that air hitting the tandems.
  5. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    All of our trailers are skirted but no air dams.
    truckdriver31 Thanks this.
  6. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Did you record any numbers before and after installing Airtabs to see how much your mileage improved?
  7. DUNE-T
    DUNE-T Road Train Member
    7,053
    17,190
    May 10, 2015
    Detroit, MI
    My computer on 1999 Detroit engine also shows 9.4-9.8 mpg, does not mean it's true. Do you fill up the tanks all the way, then divide miles driven by gallons used?
  8. tnevin225
    1,166
    1,601
    Jan 1, 2014
    To many variables, there would be no way to do that with ant accuracy, Even if you had the exact same route every day things are always changing like the weather. Do you keep a 30,60,90 day average for your truck? In general the airtabs should get you 1-3ths
  9. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    That is old tech. My truck is a 2018 so is much more accurate. Keeping track of gallons pumped and miles driven is far too much trouble and I would be unhappy if the results were less than the on board computer.
    DUNE-T Thanks this.
  10. sirjeff
    sirjeff Medium Load Member
    Now I know y'all like to hate on kevin Rutherford, but theres an app called "fuel gauges" just search for let's truck in app store or google play.
    Literally 10 seconds to add a fuel entry and keeps track for any duration averages you like.
    My REAL numbers are always BETTER than what the ecm estimates
  11. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Old tech that's the same "new tech" being done by a computer. It's nothing special. It's simple math a mind is a terrible thing to waste. I try to exercise mine often. Your truck is more accurate how did you check the accuracy?
    fordconvert and Intothesunset Thank this.
