clutch and gas
Discussion in 'Questions From New Drivers' started by BobCarnell, Nov 25, 2021.
  1. BobCarnell
    BobCarnell Bobtail Member
    Nov 25, 2021
    I'm about to apply to CDL school and I've been watching the videos about the in-cab inspection...brake check. It seems they put the truck in first gear, but, nobody mentions keeping the gas engaged when letting off the clutch as you would with a car in gear. Is it necessary to give it gas when you have the truck in gear and release the clutch like a car?
    austinmike Thanks this.
  3. kemosabi49
    11,068
    48,448
    Jan 13, 2013
    SW Arkansas
    No. You just ease out the clutch and get it started rolling before you gas on it. And the clutch is not like a car either. You only push it in part way when shifting. All the way down engages a clutch brake that makes it easier to get into gear when stopped.
  4. AModelCat
    166,357
    Never use the throttle when taking off. If it stalls or shudders/shakes when taking off you're in too high of gear. With the amount of torque available in the low RPM range you can literally tear that truck apart.
    Good rule of thumb when driving a truck is never have a foot on the clutch and the throttle at the same time. One or the other.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Yup. Even 140,000 lbs stopped on an 8% grade. Just ease out the clutch until it’s idling away with your foot off the pedal then apply the throttle. Definitely bull low first gear for that.
    Zoltan1a and MACK E-6 Thank this.
  6. tscottme
    tscottme Road Train Member
    Do not apply the accelerator until clutch pedal is fully up. This is a fundamental difference between semi-trucks & passenger cars.
    MACK E-6 Thanks this.
  7. MACK E-6
    50,326
    241,463
    A truck isn’t geared like a Honda Accord. No throttle needed to get moving.
    I can actually take off with no throttle in my pickup.
  8. 201
    201 Road Train Member
    12,917
    26,597
    Apr 16, 2014
    high plains colorado
    "ooh, that smell,,,can't you smell that smell",,:eek:
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Just a small point. Learn to use the words "throttle" or "accelerator" as opposed to "Gas Pedal. We all know what you are referring to, but, many CDL instructors will correct you on that.......over and over and over! Just some food for thought.
    GYPSY65 and buddyd157 Thank this.
  10. 201
    12,917
    26,597
    Apr 16, 2014
    To me it was always a "foot feed",,
  11. Dockbumper
    3,778
    9,863
    Apr 29, 2020
    I'll bet you call the brake pedal the "Treadle Valve" too! Lol:D:cool:
