Clutch brake adjustment?
Discussion in 'Volvo Forum' started by ErieMcDreary, Dec 29, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    Can it be adjusted, or is it time for a new clutch?
  3. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    It should be adjustable unless the brake disc has failed.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If after you pay the shop to ck. if you have enough clutch brake to get it adj. if not then they cut it out and put in a 2 section clutch brake that does not make them take out trans. Any truck parts store sells the 2 part clutch brake? Its important to tell them you know about the 2 part brake so they do not sell you a clutch job that you may not need.
    Dave_in_AZ, xsetra and 062 Thank this.
  5. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
    Talked to Volvo today, they said some are adjustable. I'll know tomorrow.
    Interesting about the 2 section deal, I'll discuss that with them.
  6. Ridgeline
    22,721
    123,352
    Someone explain how it is adjusted?
    every one of them I have replaced or truck driven never had an adjustment.
  7. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    The linkage going to the clutch. Shorten it or expand it.
  8. Inderjit
    768
    735
    Sep 17, 2017
    A 2016 Volvo VN has a hydraulic clutch. To adjust it you start by using a bar or
    a length of wood to hold the clutch pedal to the floor. You then go under the
    truck and remove the small 4"x 6" cover from the bottom of the bell housing.
    You will probably need to rotate the engine to get the adjuster to the bottom.
    The adjuster has 2 3/8" bolts holding it in place and a 5/8" hex in the middle
    for adjusting the clutch.
    Once the adjuster is at the bottom you push it in to unlock it and turn it clockwise.
    I would start with 1 turn at a time till you are happy with the adjustment. Make sure the adjuster pops back out once done.
    baha Thanks this.
  9. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
    The clutch itself doesn't need adjusted, just the brake. I can't put it into gear without grinding to get the gears to stop.
    Just talked to Volvo, they want to replace the clutch.
    Going to talk with the other shop I use, and see what they estimate.
  10. AModelCat
    164,668
    You don't adjust the brake. Adjusting the clutch itself is what keeps all the neccessary clearances in check. Typically 1/8" fork to release bearing and 1/2" bearing to brake clearance. So long as nobody dicked around with the linkage (if its not hydraulic) that should give you about 1-1/2" free pedal and clutch brake activation just before the pedal hits the floor.
  11. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
