Clutch brake gone
Discussion in 'Experienced Truckers' Advice' started by MackRookie, Oct 26, 2018.
  1. MackRookie
    MackRookie Light Load Member
    193
    25
    Nov 30, 2017
    Canada
    Hey when im at a full stop. Putting it into first gear takes grinding. Called mechanic said its probally clutch break. I showed him last time and he said its auto adjust clutch. So am i looking at a new clutch?
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Probably should start with a new mechanic, last one left you hanging.
    Dave_in_AZ and Lepton1 Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The truck parts place will sell a 2 part clutch brake that can be put in without pulling trans?
  5. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    I think that is how Volvo and Mack clutches are, they are not adjustable. Once it gets to that point, it needs a new clutch.
  6. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    Sorry i changed my truck to a freightlinrr cascadia now 2012
  7. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    SAR Thanks this.
  8. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    International is like that also
  9. MACK E-6
    50,046
    238,476
    Well, on the ‘05 Vision my 579 Pete replaced, that clutch was adjustable.
  10. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    When I'm at a stop, I leave the transmission in neutral. Without a clutch brake, if I'm on an upgrade, or flat ground, I'll keep the clutch on the floor and firmly move the stick into low gear when it's time to move. Minimal to no grinding.
    With or without a clutch brake, on a downgrade, keep the trans in neutral and your foot off the clutch (easier on the release bearing and clutch brake). When it's time to move, release the brake and let the truck start rolling on its own in neutral. If the grade is steep enough, you can let it roll until your road speed is sufficient to allow you to skip low range and float right into high range 6th or 7th without touching the clutch.
    The clutch brake is not necessary equipment.
    Wicked Wizard and TIMPTE 527 Thank this.
  11. shogun
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    I’m not sure when they switched to the hydraulic style clutch. Basically on the newer trucks they just checked the reservoir and said if it wasn’t low they couldn’t do any adjusting.
    MACK E-6 Thanks this.
